Locked out of 2009 ml350
Old Feb 6, 2025 | 03:24 PM
d2Benz's Avatar
2017 GLE350 4MATIC, 2009 ML350 4matic, 2005 4maticWAGON (sold), A Pre-facelift W210(sold)
Need help.
Car battery dead, remote can’t open door.
key blade not opening the door. It turns clockwise and not counterclockwise to open the door
is there any other ways to get inside the car.?
Old Feb 7, 2025 | 03:29 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Originally Posted by d2Benz
Need help.
Sorry If im telling you something youve already tried, but many get it wrong. The Key blade does not open the door. Insert it, turn in 45 degrees clockwise. Leave it there. Nothing will happen until you pull on the door handle very quickly 3 or 4 times as fast as you can. The later action will open the door.
Old Feb 7, 2025 | 05:54 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
They must've changed the way the lock operates between the 164/166 platforms. On my '13 the mechanical key must turn counterclockwise to the 9 o'clock position to unlock and to the 3 o'clock position to lock, much like every other car in my stable. Once unlocked, pull to open.
Regardless, I'd be inclined to shoot some TriFlo teflon lube in the keyway and in the slot the handle goes into.
Old Feb 11, 2025 | 07:08 AM
BlackML550's Avatar
@d2Benz So did you get in?
Old Feb 12, 2025 | 11:27 AM
d2Benz's Avatar
No, not yet. I have a W166 and don't drive the 164...I did spray wd40 in...no luck...I will try the trick you suggested. later
thanks for following up with me. I appreciate and will give a feedback
Old Feb 15, 2025 | 01:52 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Need help.
Try turnign the blade clockwise, 90 degrees, that's as far as it goes. try it a few times to get the hang of it. Then, turn the blade clockwise AND simultaneously pull the handle. All very gentle.
Old Feb 18, 2025 | 12:52 AM
d2Benz's Avatar
UPDATE
thanks BlackML550 and anavabi turning the key clockwise and pulling the handle worked. HOORAY!!!!!
I appreciate your response . I'm sorry for the late response
cheers!!!
Old Feb 18, 2025 | 08:31 AM
BlackML550's Avatar
UPDATE
cheers!!!
No stress although I did get it wrong - its 90 degree turn of the key.
