M273 (5.5L) Oil Pan Leak
Old Jun 3, 2025 | 11:21 AM
OUZO Power's Avatar
JGC SRT, ML 550, GLB 250
Well I've had a leak now for a few months. I thought it was the power steering reservoir. Went for an oil change the other day and the oil change guy says its leaking from the oil pan at the front.
Is it a gasket that needs to be replaced? How involved do you think this is?
Thanks in advance guys.
Old Jun 3, 2025 | 11:27 AM
imtheking's Avatar
Former R230, W220 and W221 owner
I also had a small leak. I changed the gasket and even bought a new bolt and it still leaked. My pan was rusted near and around the the bolt so than I put on some silicone to seal it and have been fine ever since.
If you want to change the oil pan, the subframe needs to be dropped. You're looking at around $400-$500 labor.
Old Jun 3, 2025 | 11:39 AM
OUZO Power's Avatar
And you had to leave the subframe part till the end. Damn. Thanks bud.
Old Jun 3, 2025 | 03:14 PM
OUZO Power's Avatar
Oh wait. You said if I change the oil pan the subframe needs to be dropped. But not for the gasket? Is this correct?
Old Jun 4, 2025 | 03:09 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Check your oil cooler first. Its up high so it drips over the power steering pump that eventually splashes it everywhere
Old Jun 4, 2025 | 10:20 AM
OUZO Power's Avatar
Huh. Good recommendation. I will take a peak at that tonight. But that's next to impossible to replace on the V8 with the very little space available. Thanks bud.
Old Jun 4, 2025 | 12:22 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
check under your oil cooler on the right side of the engine first.
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 4, 2025 | 02:05 PM
OUZO Power's Avatar
And that's where I noticed all the oil when I first checked. If it was the oil pain only it should not have climbed up above the pan. Correct?
Old Jun 4, 2025 | 10:56 PM
Joshinator99's Avatar
ML 63 AMG
Originally Posted by OUZO Power;[url=tel:9172650
9172650[/url]]And that's where I noticed all the oil when I first checked. If it was the oil pain only it should not have climbed up above the pan. Correct?
Agreed.
Old Jun 5, 2025 | 05:04 AM
BlackML550's Avatar
Not hard. You do have to remove the power steering reservoir (not the pump) and that's a 20 minute ad straightforward job. Buy a new one whilst your at it as they have an internal filter which you can't change. They're cheap. Get the O ring as well. Then the oil cooler is just a few bolts to remove.
Old Jun 5, 2025 | 12:24 PM
OUZO Power's Avatar
Makes sense. I've done that before. Wasn't fun. Had to tape together a makeshift tool to remove that reservoir cause it was right against the top cross member. PITA.
Old Jun 5, 2025 | 12:36 PM
EWT's Avatar
EWT
11 ML550, 95 Supra TT, 14 Audi S4
A tip for doing the reservoir is to tie a string or wire around the circlip when you put it back on so you don't have to search for it when it doesn't seat properly the first time. Also, if it is leaking from the cooler, I'd recommend getting a new cooler rather than just replacing the seal so you don't have to do the job twice like I did. The cooler is reasonably cheap ($50ish IIRC from FCP Euro).
Old Jun 5, 2025 | 02:36 PM
OUZO Power's Avatar
I did the C clip trick back then. I'm to old now. 52. I will pay for it.
Old Jun 5, 2025 | 04:20 PM
SPONSOR
the entire assembly is cheap enough so you don't have to bother with replacing both gaskets.
__________________
Old Jun 5, 2025 | 05:44 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
If you are still having trouble finding the exact spot of the leak, clean up the areas you see oil deposits very well and watch where the leak starts. As mentioned above, leaks do not generally travel upwards so inspect from the top down.
Old Jun 6, 2025 | 07:54 AM
imtheking's Avatar
Correct, the gasket itself is easy. If the oil pan itself needs to be replaced, the subframe needs to be dropped.
I know this because there was an issue with the ML where when you first start the car every morning, you would hear this noise that sounds like putting paper into a spinning fan. It was because of the o ring on the oil pick up tube located inside the oil pan.
Check out this thread. if you ever needed to do replace the pan, the directions are here. Including the fix for the cold start rattle
https://mbworld.org/forums/m-class-w...placement.html
Old Jun 6, 2025 | 02:31 PM
EWT's Avatar
EWT
I've got 9 years on you, but I enjoy wrenching and could get it replaced in the time it would take me to drop off, talk to a service writer and pick up.
Always a good excuse to buy new tools as well. Just picked up a long wrench with a flexible head to replace the supercharger belt on an Audi.
Old Jul 3, 2025 | 11:12 PM
OUZO Power's Avatar
It ended up being just the power steering res.
Old Jul 3, 2025 | 11:30 PM
ML 63 AMG
Originally Posted by OUZO Power;[url=tel:9184291
9184291[/url]]It ended up being just the power steering res.
Well that beats having screw around with the oil pan…! 👍
