Aftermarket Tow Hitch
Any thoughts on a aftermarket vendor? Also will attaching to the wiring be an issue?
So an aftermarket hitch may cause a crack in a panorama roof as its near impossible to mount the same way. MB can mount afterword but its not the same hitch or class.The factory hitch also has a switch to tell the computer a trailer is attached and uses an anti sway program. Why we continue to buy aftermarket items to save a $100 or $200 is beyond me. Resale nightmare in most cases and you loose what you saved and then some.
Off topic, but hopefully useful to someone.
Wayne
No worries. I found a Curt 2" tow ball, locking pin and 7-4 electrical adapter at two auto parts stores back here in the woods. My dealer reimbursed me. MBUSA was not involved.
Wayne
I said my mini-rant was
I am talking about the GLK. Ordering the factory trailer hitch gets you the fixed bits attached to the GLK and the electrical outlet for attaching a 7 pole to 4 pole lighting adapter that accepts the 4 pole connector from the trailer. One more time: From the factory, the GLK hitch is non-functional.
GLK GLK GLK
Not ML.
Wayne
GLK GLK GLK
Not ML.
Wayne
So if I understand you correctly you are talking about the GLK? :-)
GLK GLK GLK
Not ML.
Wayne
So I understand someone being upset if that was promised, but it's certainly not the norm.
To add insult to injury, the MBUSA web page lists the GLK hitch as Class III. Wrong! One of several typos on the web page.So I understand someone being upset if that was promised, but it's certainly not the norm.
Wayne
Chilled in Texas.
What hitch did U-haul install?
Before we go down the buy it with it from the factor, I bought off the lot and didn't have the option.
Thanks.
http://www.hitchweb.com/product/88/1...-Benz-GL-Class
