Anyone know how to activate the HOLD feature when stopping gradually.
If I leisurely and gradually stop I can't get the darn thing to activate.
Read the manual on it, but no luck.
Any takers.?.
No S mode in the ML.
"The HOLD function can assist the driver in the following situations:
- when pulling away, especially on steep slopes
- when maneuvering on steep slopes
- when waiting in traffic
The vehicle is kept stationary without the driver having to depress the brake pedal. The braking effect is canceled and the HOLD function deactivated when you depress the accelerator pedal to pull away."
IT WAS CALLED HILL START ASSIST.............things do change though LOL
Hill start assist helps you when pulling away forwards or in reverse on an uphill gradient. It holds the vehicle for a short time after you have removed your foot from the brake pedal. This gives you enough time to move your foot from the brake pedal to the accelerator pedal and depress it before the vehicle begins to roll.
- Take your foot off the brake pedal.
- Once you have taken your foot off the brake pedal, the vehicle is held for around one second.
- Pull away.
Hill start assist will not function if:
- you are pulling away on a level road or a downhill gradient.
- the transmission is in position N. Rthe electric parking brake is applied.
- ESP® is malfunctioning.
Note that with Hill Start Assist, you do not need to further depress the brake pedal, which you must do for the HOLD feature.
Strangely it does have the ECO Stop/Start as do the diesels, but the ML350 & ML500 petrol miss out.
