2013 ML350 BT blind spot?
My had found the steering of the ML is not precise. It's a little uncertain at low speed especially when parking. Unlike my 4runner and Lexus which I know exactly where the wheels are and the heading, I sometime over-steer the ML
The blind spot that I am having trouble is the front-right.
Anyone has the same experience about this uncertainty or wheel direction at low parking speed?
The Lexus is completely different category of car and relatively tiny.
As for your front right, it sounds like you need more time as you probably spent over a decade with the 4r, and the ML is not easy to judge with the corner.
I love the truck!
I am not sure it's the A-pillar or the seating. It's not easy to find or judge where the front wheels some time on how closer to the cure/sidewalk at low speed.
I hope time will allow me to adjust to the ML.
I'm sure you will get used to it in short order. Enjoy your new ride! Revel in the incredible mileage & power.
I think I will try to re-adjust the seat and make it a bit higher to see if I can get a better view and feel.
I agreed with you that the front hood is sloped and dipped at the end so I could not see the front's end. Maybe this is my problem.
http://ergonomics.about.com/od/car/s...ivers_seat.htm
