X5 to ML350 BT today
We chose Diamond white with black interior, P1, driver assist, headlight option, trailer hitch, running boards (we had these on the x5 and found they protect you from other car doors in parking lots). Went in on the last day of the month, they came down over 10% and increased the value on the trade.
Looking forward to Wed!
You can also park to the left on a one-way street but the car doesn't automatically look for a space to the left. To make it look to the left, engage your left turn signal while driving forward at a slow-ish speed. If it finds a spot to the left, you'll see an arrow pointing left instead of right. The process is the same from that point.
The radio does not turn off when the car motor is turned off. I have to open the door. (I have keyless entry.)
The windshield wipers on the drivers side wiggle big time and make a lot of noise. (there are other posts about this problem on this forum.)
To change radio channels, unless you use voice control, there are too many mannual moves required.
Being right eye dominant, I automatically look to the right gauge, but the speedo is the left gauge. So, I now rely on the digital read. (I know... But I said they were nits... Except for the wiper blade which is not acceptable.
The lane control goes off even if you are turning a corner.
The headrest won't go back enough so it forces my head to lean forward.
Not something I did not know before I bought the car, but virtually all the MLs on the dealer lot for sale when I bought mine had all these gizmos -- do I really need mood lighting -- but vinyl seats. Vinyl seats for a $55,000 car? I know I could have "ordered" a car to spec, but, of course, would have paid a lot more.
But, with all that, I still love the car.
But as I pull into the garage, I like to listen to the end of the commentary as the garage door closes without ingesting CO2.
-The windshield wipers on the drivers side wiggle big time and make a lot of noise. (there are other posts about this problem on this forum.)
This happens to some but certainly not all. I suggest there may ber faulty components out there which require the dealers to get off thier bums to fix!
-To change radio channels, unless you use voice control, there are too many mannual moves required.
One can push the arrow buttons next to the volume knob to change it.
Or you can push a keypad number for a preselect station.
And a single push of the "RADIO" button will change from AM to FM and back.
-The lane control goes off even if you are turning a corner.
On multi lane roads yes! It does not realise the car beside you is turning also.
I have turned this feature off as I am continually crossing the line on narrow mountain roads.
-The headrest won't go back enough so it forces my head to lean forward.
Have you tried pushing the button on thew side of the headrest? The headrest does come forward as part of Presafe, but needs to be manually returned.
We will always have complaints about a car no matter what we have.
But except for the wipers, yours are minor or part of the learning curve.
Enjoy your car!
I would bet that a new X5 does the same thing. I know a new X3 does because I sat in the dealer's lot and played with iDrive after I had turned off the engine.
