Pic request: jack for cars with the sport package and side skirts
Old Jan 15, 2014 | 11:39 AM
jtorrebl's Avatar
2025 Panamera GTS
No running boards. Did the conversion from running boards to sport side skirts.
Found that I needed new jack point inserts under the car and then my jack wouldn't fit without cutting off a 1 inch nipple that stuck up for that contact point on the jack.
Old Jan 15, 2014 | 11:47 AM
Chasvs's Avatar
ML350 Bluetec
Here ya go!
Attached Thumbnails Pic request: jack for cars with the sport package and side skirts-image_21812.jpg
Old Jan 15, 2014 | 01:33 PM
another_geek's Avatar
'16 Jaguar F-Type R, '21 GLE63s
I bought one of these a while ago when I had my W164. Allows you to use any standard floor jack.
http://www.reverselogic.us/mercedes_jack_pad.html
It looks like the same part will work for the W166 also, but I haven't tried it.
Old Jan 15, 2014 | 02:23 PM
threeMBs's Avatar
Only MBs - the best or nothing
Thanks for posting link. Very useful
Old Jan 17, 2014 | 12:25 AM
jtorrebl's Avatar
2025 Panamera GTS
Originally Posted by Chasvs
Here ya go!
No, I meant the little factory jack that you'd use in a road side emergency
Old Aug 11, 2019 | 08:46 AM
frank94's Avatar
2015 Mercedes-Benz ML 350
center jack point on front and real for 2015 ML 350
Good Morning,
Anyone know where are the front and real center jack point for 2015 ML 350?
Frank
Old Aug 11, 2019 | 01:08 PM
vinceC's Avatar
2014 ML350 4Matic
Originally Posted by frank94
Good Morning,
Frank
At the front there is a lateral rectangular pad that protrudes from center of the under tray. At the rear use the diff.
Old Aug 12, 2019 | 09:58 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
I also removed my running board but put the standard rocker back on. When I took the running boards off i removed the four jack pad . The pads with the running board are really two pieces snapped together to make the drop lower(thicker) so it will sit below the running boards. I separated the two piece pad and reinstalled the base plate back on the car. One problem I had was I could not screw them back on as they came from the factory. What I did was glue them on, but putting glue on it and the jacking it up with a floor jack and let it set over night to make sure it was firmly attached.
It works great, but I have never used or looked into using the jack that came with the car. I just keep a can or two of sealant to use if I have a flat.
