Key FOB Not Detected
I expect MB can do better than that. Shoot, I'd expect Chevy to do better.
I wonder if its an early warning that you car battery needs replacing. Or perhaps there is a poor solder joint on the connection from the battery/ fuse panel to whatever device detects the key fob. Either one of these would result in lower voltage at the key fob detector which may cause it not to work. But if you start the car and let the battery charge, the voltage would increase and it might work fine for a while.
On my BMW, when the battery starts to go, then the car throws some really weird electrical errors that seems to be completely unrelated to the car battery. Its funny because the battery is still strong enough to start the car, but the lower battery voltage causes things like the push button key fob not to work, or the idle speed to hunt from 500-800rpm, or other weird stuff. After 17 years of owning my 540, checking the battery has been my first thought every time anything electrical on my car fails - and it has been the culprit almost 100% of the time.
Hopefully this is on the right track to solve the problem. One simple test if you have a trickle charger: I wonder if the higher voltage of the trickle charger connected to the battery (after not running it for 4+days) would cause the fob detector to work. Try it without first, confirm is doesn't work, and then connect the charger and try again.
Bottom line - up to you. You can't know exactly what the dealer did: perhaps they stored it heated indoors and the battery maintained its charge better; or perhaps the dealer's car jockey had to move the car a few times, or decided to wash it, so it actually didn't sit.
Other than radio interference or car battery issues I can't think of anything else that fits the description.
