360° camera control unit
Old Apr 26, 2017 | 02:16 PM
Pluton1795's Avatar
ML 350 Bluetech
Hi All
in the process of retrofitting my ml 350 w166 360° camera surround view.i have a concern about 360° control unit connector, want to know the name of such connector, where can i found it. and second question, the correspondance between schemas pin number and connector pin.
need the name of the white connector.
need to know the correspondance between the pin numbers in schema and physical pin in the last picture
thanks for your help.
Old May 1, 2017 | 03:39 PM
Pluton1795's Avatar
ML 350 Bluetech
Hello All
No one know the pinout ?
Old Jan 18, 2018 | 02:56 PM
Pscheuer's Avatar
2015 SLK250
Trying to add the 360 degree controller to my SLK250
Did you have any luck finding and installing the wiring harness?
My 2015 SLK 250 WITJ NTG 4.5 command system will lete select camera=SVC, bit i don't know what other part besides the controller and cameras to make it work.
Old Jan 25, 2018 | 11:35 PM
jrsmith_68's Avatar
Veteran: Army
2007 C350 2015 ML400 1968 Ford Mustang
Originally Posted by Pluton1795
Hello All
Normally the pins are numbered inside the socket and on the plug. From your photo it looks like there are numbers in there. Have you used a flashlight and looked inside?
Old Feb 11, 2018 | 01:42 AM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Pluton795 Any luck on your camera project.
Old Feb 11, 2018 | 03:00 AM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
hmmm... interesting I know a few connectors that look they would fit, you need a total of three. I think it is easier to just get the wire harness.
Old Feb 11, 2018 | 03:05 AM
JohnnyC's Avatar
I have the partial white connector; it is 001-545-11-73. This works with the 8 pins. Not sure about the 4 pins yet.
Old Jul 22, 2019 | 05:57 AM
yiannossavva's Avatar
Gcl 220d 2018
Old Jul 22, 2019 | 05:59 AM
Gcl 220d 2018
The other 4 pins not needed
i start too to retrifid w212 with same controller :-)
