ML 350 W166 - Centre Console Arm Rest Latch broken
Old Aug 25, 2017 | 02:45 AM
bothra's Avatar
ML 350 2015
My ML 350 has a unique problem. Latch of Right Side arm rest seems to be broken. Any ideas on how to fix it?
Old Aug 26, 2017 | 05:47 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
https://mbworld.org/forums/new-m-cla...e-removal.html
Old Sep 11, 2018 | 10:40 AM
scottmeyers's Avatar
2015 ML 350
Bothra: Did you ever resolve your broken latch issue? Mine also broke. The dealer said they don't sell the latch by itself. It would cost over $900 to replace the entire console but I am not willing to spend that much over a tiny piece of plastic. Help please, thank you.
Old Sep 22, 2018 | 09:42 PM
eahearn's Avatar
2015 ML250D, 2024 VW Golf R
Same here. Right side latch broke. Haven't been able to figure out how to resolve it without replacing the entire console, which is ridiculous.
Old Sep 23, 2018 | 01:16 AM
fabbrisd1's Avatar
A gaggle of MB's
About $300 for the part - but you need to give your dealer your VIN# so they can give you correct part# for your interior:
https://www.parts.com/?fuseaction=st...z-2013-Armrest
Old Oct 15, 2018 | 10:36 AM
jdward's Avatar
2013 ML350 BlueTec
You can get the armrest disassembly and reassembly instructions on this thread.
https://mbworld.org/forums/m-class-w...ment-w166.html
Old May 1, 2019 | 07:50 PM
jcbarrozo's Avatar
2013 ML 350 4Matic
I have the same issue. Maybe they need to do a recall on this problem. My wife used black electric tape to hold it for now. Anyone here able to fix this problem? I just need to be able to remove that center console and look inside if there's a spring that came off or something. Any help here is appreciated -2013 ML 350 4MATIC. If anyone needs the VIN # please let me know.
Old May 1, 2019 | 07:58 PM
eahearn's Avatar
After dealer quoted $900 ish I just used a small amount of Velcro tape. Has worked so far.
Old May 4, 2019 | 03:21 PM
cbbfralin's Avatar
2014 Mercedes ML350
So is there not a quick fix for this? Same thing happening to mine on the right side (mL350 2014). It will just pop open from a bump. I’ve looked at the latch and it looks the same as the other side, not broken or anything. So frustrating!!!
Old May 11, 2019 | 02:46 PM
jcbarrozo's Avatar
2013 ML 350 4Matic
Okay, so I have this same friggin problem for my 2013 ML 350 4 Matic. I print out some of the pdf files I found here (with pictures) and some on another forum. Make sure you use the right one that applies. The one that applies to mine was the one that says Model 166, Model 292. So here's what I did.
There are 4 small screws that you need to remove in the center console and 2 big ones. You'll see this all in the illustration of the model I mentioned above. Then you only need to remove the back piece (with the ac vents) to remove the entire center console. There are 6 small screws altogether and you will need to detach the electronic connections. Once you do this correctly you should be able to remove the center console and be able to see underneath where the missing spring that holds the latch.
Mine was entirely broken besides the missing spring so I decided just to replace the entire armrest (part number166-680-41-03-9H15) Cost me $311.00 Dealership was charging me almost twice as much.
Old Jun 3, 2019 | 12:16 AM
JSolanoC's Avatar
ML350
I just fixed the same problem
I just make a little hole with a burn or you can heat a piece of metal, and place it iside of the plastic broke base. You will need de original spring or similar. Good look
Old Apr 7, 2020 | 05:19 PM
myanonmbw's Avatar
ML350
Fixed with ebay purchase
Hi, I know this right armrest latch problem is very common, and buying the whole console storage is too expensive.
I found the item selling at ebay. I payed $22 shipped from china or hong kong
"Right Armrest Box Buckle Lockers Switch Clip For Mercedes ML320 ML350 GL400 W166"
https://www.ebay.com/itm/Right-Armrest-Box-Buckle-Lockers-Switch-Clip-For-Mercedes-ML320-ML350-GL400-W166/164016271480
part # I see on the package is 166 680 4103-R
I hope somebody can model it to the 3d printable but, anyway I fixed this with only $22, there is another site that sell the part about $70. of course it is very expensive for the part size but it saves me a lot of money.
I am finally happy with this fix after 2-3 years with right arm always open and taping was not a solid solution.
1. remove the rubber mat from the rear bottom tray
2. unscrew the two bolts revealed with tork #20
3. unlatch the tray with two/three paper method
4. unscrew the two bolts with tork #20 accessible after laying down the tray
5. unlatch the rear plastic console frame from the top hook inside the plastic rear console frame.
6. uncrew #15 tork aside of the cable connector
7. uncrew two screwes #25 or #30(not sure) inside of storage bottom(you would need a impact wrench and long extension), 4 screws #20 as well.
8. raise up the storage and you can access the latch.
probably the spring is gone hard to find, but the item I purchase from ebay also has the spring.
when assemble back, the hard part was to latch back the tray of rear console. I used two or three papers to latch the tray without breaking anything.
I know this thread is quite old but I bet somebody someday looking exact same information will be benefited. not sure if the item would still be on sale at that time though.
double post in other thread as well to be a help to somebody.
Old Apr 7, 2020 | 07:09 PM
JSolanoC's Avatar
ML350
Good advise
Old Jul 21, 2020 | 07:31 PM
Mannygar's Avatar
ML 350
Center Console Latch Broken
Same problem with my ML 350 2015 - center console right armrest latch broken. To replace the whole assembly dealer gave me a quote of US$1,100 which I declined, just too expensive.
For now, I'll just use velcro to hold the cover down until I found someone who could fix it at a cheaper rate.
Old Jul 21, 2020 | 07:48 PM
JSolanoC's Avatar
ML350
Try to fixed by yourself or buy a replace on internet
Try to fix it by yourself or buy a replace on internet
Old Nov 3, 2020 | 03:48 PM
ducv978's Avatar
ML350
Arrow
Same problem with my ML 350, 2015 - center console right armrest latch broken.
I'm in Houston, TX, and need some to fix it.
Old Nov 3, 2020 | 08:43 PM
chassis's Avatar
2017 GLE350 4MATIC
Does anyone know if this was remedied, fixed or improved in the W166 GLE?
Old Nov 5, 2020 | 06:56 PM
degeja's Avatar
2016 E350 Sedan SPort
I screwed in a $5 magnetic latch
Old Feb 15, 2021 | 01:31 PM
GeorgeNC's Avatar
MB 350
I had the same idea. here is a picture. I took the casing off the cabinet latch. Seems to work fine!
Old Oct 3, 2021 | 01:26 PM
calvinstrehl's Avatar
2014 ML350
Step-by-step with pictures: 2014 ML350 Passenger (right) armrest latch
Complete set of instructions with pictures!!! This is a complete guide that should allow you to fix the problem for ~$23 dollars and without replacing the whole console.
This was performed on a 2014 Mercedes Benz ML 350 center console to repair the mechanism responsible for latching the passenger half of the center console armrest/compartment door. See the attached document for step-by-step images of how to gain access to the latch. I didn't show the final steps because once all the screws marked in the pics are removed, then the compartment can be pulled out of the console and the mechanism becomes clearly accessible. I couldn't have done it without myanonmbw's description below: combine that with my pics and this job shouldn't take you more than an hour or so. Thanks to everyone who contributed, hope this helps to tie things together.
As for the part I used, I found it on ebay pretty easily for $23. I would have posted the link here but I bought the last one from that specific seller. There were a lot of other identical parts from other sellers at a similar price if you search with the following info-
Part description: 1Pair L+R For Mercedes-Benz W166 W292 X166 GL Center Console Armrest Latch Clip
Cost ~~ $23
Shipping took 2-3 weeks as it came from China.
This kit came with latches for both sides but I only needed one. Make sure you buy a clip with the spring included. Some threads I read people tried to find the lost spring within the console with a lot of hassle and without much success.
I believe the only tools I used were a flathead screwdriver (for prying) and T15 and T25 Torx screwdriver bits. Be careful when putting the screws back in because they are in precarious places and if they fall they will be lost forever. Best to use a magnetic bit holder or something.
Good luck!
Sellers part description/image
Old Oct 3, 2021 | 09:10 PM
chassis's Avatar
2017 GLE350 4MATIC
Nice work. Link to part with spring:
https://www.ebay.com/itm/384355564181
Seller is kinggoods-us
Old Oct 16, 2022 | 04:37 PM
Vijay Ladani's Avatar
ML350
I recently fixed broken right side latch clip of center console armrest in my ML350 2014. Revert if you need any help. I can personally help if you are in DFW area and will fix it in less than $100 including parts.
