2012 ML350 4Matic brakes
Was at the dealer for oil change and looks like I need brakes. Pads and rots. I had the dealer give me the part numbers of the parts. When looking them up, the rear rotors and pads it is saying for ML350 with AMG package. My ML does not have AMG package. I am finding it strange. I guess there is vented and solid rear rotors.
Below are numbers they gave me of what I need.
166-421-1300
166-423-0600
000-420-3302
007-420-7820
164-540-1017
211-540-1717
220-421-0171
019-990-5601
018-990-0001
I am at a loss. I do not currently have the car to check the rear rotors to see if they are vented or not. The VIN# 4JGDA5HB5CA086613
It is confusion and therefore I questioned the part numbers and the dealer confirmed those are correct. QAny help would be great. Looking to order the items I need so I can do the brakes.
Thank you.
166-421-1300
166-423-0600
000-420-3302
007-420-7820
164-540-1017
211-540-1717
220-421-0171
019-990-5601
018-990-0001
Thank you.
I have not seen any ML350s here in Canada that have solid rear disk as all of them have the AMG package. Whatever kind of rotors you have I would recommend going with Zimmerman rotors and Akebono pads then you almost get rid of the dust plus stopping power and brake feel is the same as stock setup.
Looks like mine are also vented in the rear. I thought Zimmerman rotors are prone to cracking. I was going to get oem but they are expensive. Have many here used Zimmerman rotors?
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
While the Akebonos produce less dust than OEM, their braking performance is NOWHERE NEAR the OEM pads, and furthermore will warp the ML350 rotors the first time you have to make a couple of rapid stops in succession (assuming that you actually manage to stop before you hit whatever is in front of you). They may be fine for 70-year-old grandmas in Florida but not much else. I wouldn't put those on an ML if someone paid me to use them.
166-421-1300
166-423-0600
000-420-3302
007-420-7820
164-540-1017
211-540-1717
220-421-0171
019-990-5601
018-990-0001
Thank you.
166-421-1300
166-423-0600
000-420-3302
007-420-7820
164-540-1017
211-540-1717
220-421-0171
019-990-5601
018-990-0001
Thank you.
not yet a Grandpa...LOL!
To the OP... call another MB dealership with an 800#, give them your VIN, and they will give you the part #s fitted to your vehicle. From there, you can search for the right parts, assuming no updates from aftermarket, etc... just to verify your #s
Koenig1 - I guess our experiences differ. I haven't personally run Akebono's on my ML, but I have on my Volvo in the days when I was more concerned with style over substance, and have furthermore seen probably two dozen Porsche / Audi / VW owners come to the shop in the last couple of years alone with ceramic pads - usually Akebonos - complaining of poor braking performance and/or warped rotors. I too have been racing cars for the last 15 years and have partial ownership in said shop, and my own experience is 100% in line with that of most automotive professionals.
If you want a quick read, see http://www.autoanything.com/brakes/t...-metallic.aspx or http://www.cquence.net/blog/ceramic-...tallic-brakes/, and for an actual review of them on an ML see the second review at https://www.tirerack.com/brakes/brak...o+Ceramic+Pads. In short, they do not have anywhere near the bite and stopping power of the OEM or other semi-metallic pads, and they do not absorb or conduct heat which half the time results in warped rotors the first time you have to make a panic stop on a heavier vehicle like an ML or any other SUV.
As for the rotors, I've never had or seen any issues with Zimmerman. We've sold them and used them on various street and track cars without issues, and they have been the OEM supplier for a number of BMW and Porsche models for a number of years. 99% of all problems with any reputable brake rotors are a result of using the incorrect pad for the application (like ceramics if the rotor size isn't also increased) or post manufacture third-party cross-drilling.
