Turn signals randomly quit working - Yikes!
Ummm, nice 'effort' Plutoe, but try again. My 'issue' is that I'd like to be more informed about the system, how it works, what it interfaces with and what the common (if there is one) failure point is in said system. In case you've forgotten, that's one of the primary things these forums are good for - knowledge. IMHO - there is no better way to minimize the chances of being screwed by a service department (dealer or independent) than to know exactly how something works, so when they make a suggestion, your only option isn't to just nod your head, say OK, open your wallet and hope they know what they are doing.
May not be be the same problem, but it seemed SAM modules can cause pretty strange electronic behavior despite everything else seeming normal. Since having them replaced, no other odd behavior. Not sure if there’s a handy way to repair a defective module, but the service advisor told me how many different electronic control components were in the ML and I was surprised.
When you had this issue, would turning the ignition off and back on 'reset' the system and make the turn signals work again? I'm trying to understand how a simple electro-mechanical item can fail in that way, but I suppose since the output from that item feeds into a module (not directly to the bulbs) anything is possible.
Second, while the signal is a switch, the input of the switch is read by the Steering Control Module at the top of the column. Then that signal is communicated to the Front SAM via CAN. If after the signals quit working, but you can get your hazards to come on, I would suggest that your SCM be replaced. Hazards are requested by the Upper Control Panel over LIN, but also to the Front SAM. The front SAM is located on the right side of the dash directly under the A pillar.
Yes, that would be great - Thanks. Truck is at the mechanic's today and it would be great to be able to match up your diagnostic with his...
Have to say I am disappointed with this car. I'm only at 32,000 miles and have had so many issues. More than I've had with my 2001 E320 that has 140,000 on it.
