Smelly air vents on Startup - no water draining from AC System? Anyone else?
All my other cars drip lots of water from the evaporator after the car is parked / turned off. I notice my merc doesn't which leads me to believe that a drain tube is blocked causing this smell.
Does anyone notice that their car DOES NOT drip water after the car is parked, AC was on, and it's hot/humid outside?
"Class Action" - yeah, right... whatever..I'll sell you a Fantasia Passport..
1. Remember there are affordable "evaporator" and "auto aircon cleaners" out there - the best ones have long thin plastic tubes you insert down each dash vent - releasing the chemical deep in the system - draw tube slowly out - cleans duct as well. Pricier in Canada than US - but not cripplingly expensive DIY
2. "Gym shoe" smell in most cases is caused by evaporator frosting up - like the back of a old fridge - then after car is stopped/parked - the frost melts leaving interior of the system wet/moist - which in turn allows mold/mildew like to grow/build
3. Could your drain be clogged - possibly - most cases my tech see are owners who keep their system on "Lo" or at real low temp - rather than auto - so during drive time evaporator frosts up - which in turn lowers system efficiency - feeding the thought "I have to keep it low to stay cool" when actually it is frosting up the system..
I have yet had a customer "admit" - but I have my service techs check climate control systems on checkin - and 80%+ are unintentional driver settings..
5. Mercedes US uses the "Wurth" evaporator/system cleaner - and they change out the filters at the same time
Keep the beat !
Just the simple fact that a significant percentage of owners are experiencing this problem, proves that their actions are not unreasonable.
I love my car, but this issue is my biggest gripe.
My solution has been to try to remember to turn off AC compressor a few minutes before parking the car for an extended period of time.
I can't help thinking my evaporator drain lines are blocked.
Keep the beat !
Is it normal for this car to not drip water after it has been turned off? I'm wondering if my evaporator drain tubes are clogged. Haven't been able to locate where they are either.
There are tons of posts on this forum about this problem. There's a technical service bulletin (which mine has received the 'repair'), but it still smells (not an absolute fix).
I've started shutting off the AC (press the AC button) and leaving it in the AUTO mode....therefore running the vent. Do that for the last 5 min of your trip. That makes a difference for me.
For my next service interval, I plan to replace all filters (combo & dust), and maybe I'll do one of those spray cleaners then. That may help.
That's why I don't want to hear people blame the occupant, about what setting they're using.
Wurth has a decent system cleanup product - so does Nextzett (formerly Eiznett) - and (1) Cleanup & (2) fresh filters & (3) adjusting owner settings take care of the problem like 100%.
I have customers who "swear on the Bible" they set at 72 - and the fact is they/or-significant-other put their settings back to Lo..
I don't even have "LO" on my panel. I'm not sure what you're talking about; I have a temp dial. I can't imaging 80% of people turning the temp dial all the way down to 60, and then manually lowering the fan all the way down...and trying to control the temp in that fashion....is that what you claim people do?
Regardless, the system should be able to handle that.....most compressors cycle on/off accordingly, to prevent evaporator freeze-up. All evaporators of every AC system are designed (or should be designed) to deal with the inevitable condensation that happens. In fact, that's one of the main reasons for the evaporator in a car.....to dry out the air.
We get this smell in almost every 166 here in south FL, but it's hot and humid every day of the year, worst possible case for evap moisture.
I agree, it's not an excuse, but the germans tend to try to figure out a way around it rather than change the design in a way that prevents the issue.
https://www.carscoops.com/2019/12/me...lion-vehicles/
