Low coolant light 2.1 Bluetec
Old Apr 13, 2018 | 02:38 PM
gkgeiger's Avatar
'10 C300, '15 ML250BT, '22 M850i Vert
This is the second time I've got this warning. No leaks on the garage floor. Anyone else have this problem?
Old Apr 13, 2018 | 09:52 PM
DanD.'s Avatar
2018 GLC 4MATIC
Had this once. During winter. Went to a dealer bought a coolant. Added it to cover the plastic level and newer had this message again.
Old Apr 14, 2018 | 07:22 AM
gkgeiger's Avatar
I didn't say it but obviously I added coolant the first time and again now.
Old Apr 14, 2018 | 08:18 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Does your engine seem to run any hotter than usual? Or worse, do you seem to have more white smoke out the tailpipe than usual?
Old Apr 14, 2018 | 08:32 AM
gkgeiger's Avatar
Runs perfect, never any smoke from tailpipe.
Old Apr 14, 2018 | 10:21 AM
DanD.'s Avatar
2018 GLC 4MATIC
Is it really low or just a sensor error? If its really low check the oil level. It should be somewhere.
How log ago did you add it and how much gone?
Old Apr 14, 2018 | 11:34 AM
gkgeiger's Avatar
I added about a pint each time. I've never had to add coolant to any of my many new cars.
Old Apr 14, 2018 | 12:37 PM
DanD.'s Avatar
2018 GLC 4MATIC
Did you check oil level?
Old Apr 14, 2018 | 01:55 PM
gkgeiger's Avatar
Oil is fine, no sign of water.
Old Apr 14, 2018 | 06:14 PM
DanD.'s Avatar
2018 GLC 4MATIC
As far as I know coolant can go in or out. If no leaks outside I would send oil for a test. Very strange.
