How much air pressure do you lose per month?
Old Sep 12, 2018 | 06:06 PM
c3002008's Avatar
C300, ML350
How much psi do you lose from your ML tires per month?
Old Sep 12, 2018 | 11:30 PM
HAILERS2's Avatar
Presently 19 S560 SEDAN, 2014 XK, SOLD GLE 450e
None to notice on my ML350 Bluetec......but a lb a day in my CL550's right rear tire. Gotta fix that one rear tire that loses a lb a day. Tired of filling it up every two/three days. No nail to be seen.
Old Sep 13, 2018 | 10:30 AM
c3002008's Avatar
C300, ML350
Hi,
Yeah I notice around 3 psi loss per month and I was wondering if this was normal? Didn’t notice this much loss on my c class. I don’t know if this much loss is normal,by the way I have Continental all seasons on my w166.
Old Sep 13, 2018 | 05:26 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
3 psi/month seems like nuts. Oh, and try nitrogen instead of air, leakage is reduced.
Old Sep 13, 2018 | 11:18 PM
DanD.'s Avatar
2018 GLC 4MATIC
+1 to nitrogen.
Pressure stays the same no matter how cold or hot is the weather. Love it.
Old Sep 16, 2018 | 12:34 AM
fabbrisd1's Avatar
A gaggle of MB's
If this 3lb/month is consistent month-to-month - if you haven't had a 30deg temp drop each successive month - and it's more than one tire - then you have a mounting probelm when they put on those tires - or real ****ty valve stems. If it's one tire only - then there is a bald valve stem there - or slow leak in the tire (which can be hard to spot) - or that tire/wheel has poor mounting
Correction - temperature affects tire pressure the SAME for both Air and Nitrofill - about 1deg per 10deg F
https://www.tirerack.com/tires/tiret...jsp?techid=191
Old Sep 16, 2018 | 07:19 PM
c3002008's Avatar
C300, ML350
thanks for the replies... Hi, yeah will check again end of this month-- if its low again then I will get the tires remounted.
Old Sep 18, 2018 | 12:53 AM
Oldoarsman's Avatar
MB ML 350 4Matic, Sprinter 2500 High Roof Passenger
Valve stem cores
Just a thought...you may want to check your tire valve stem cores to ensure that they are tight. This is an easy thing to do with a very inexpensive valve stem tool.
I had a similar problem years ago and this was the cause. I keep one of these tools in the glove compartment of each of our vehicles.
Good luck!
Old Sep 18, 2018 | 05:54 AM
Kartergreg's Avatar
2013 ML350 Bluetec, 2016 C3, 2020 Lincoln Aviator
... and try nitrogen instead of air, leakage is reduced.
I've tried it before and didn't notice much difference.
Now I run a mix of 78% nitrogen and 21% oxygen.
It's called air.
Old Sep 19, 2018 | 02:29 PM
c3002008's Avatar
C300, ML350
Good luck!
thanks, will try that.
Old Sep 20, 2018 | 01:56 AM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
about 2 lbs and worse when weather changes from hot to cold
