Ambient Light Retrofit / Assembly
Old 12-03-2019 | 11:18 AM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
Hi guys,
Know there's been a lot of discussion around ambient light retrofitting, and I've been a naysayer, but I want to try and understand the individual components of the system to see if a retrofit using OEM parts from eBay is actually possible.
I managed to find a section of the big dash trim piece on eBay for less than $50 bucks. Sell verified it was in working condition from the vehicle it came off of, and sent pictures.
I got the trim piece yesterday, and wanted to do a bench test with a 9v battery. Nada. Here's what's interesting from actually being able to look at how these components work. There's a fiber optic band that runs in a channel on the bottom of the trim piece, with two emitters on opposite sides of the piece, all leading to a 3 pin connector. In my head one is positive, one is ground, and the third tells the FO light emitter to send the "Solar," "Polar", or "Neutral" color through the band.
But with basic circuitry, by sending power to the light shouldn't I get one of the colors?
My other solution is to use these FO emitters I got off of AliExpress and send the light into the existing channel, bypassing the OEM emitter, but I want to try and understand how to get the OEM FO shooting through first. Here's some pics:
Old 12-03-2019 | 04:05 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
Originally Posted by we47b1me
Hi guys,
Bold Experiment. I think the person you should contact is chris the swede, PM me for more info. He would be a good resource to dig deeper into the ambient lighting assembly.
Also, be mindful of one thing. Certain MB models have the 1 color ambient lighting, which is Solar, from 2009-2011 models, I have seen it on older model E class sedans and some S sedans, i think they introduced the 3 colors from 2012 on (im thinking). I pesonally like more options that they are offering now, well my moms 16 S550 only has a few and i only have the standard 3 in the GLC.
It does make a difference when you drive a nightime though, if you ask me. Good Luck! let us how know it goes.
Old 12-04-2019 | 08:59 AM
we47b1me's Avatar
Originally Posted by chris is banned
In my ML to GLE conversion I did the 12 color . But as said that only works with new comand. For the 3 color you need to conect it to the rear SAM and then code both cluster and SAM to know its installed. Its all controled over Can Bus. Not just voltage.
I knew it was over can bus, but in my ML, it wouldn't have been pre-wired for ambient, meaning if I pulled the dash trim and door trim pieces (have looked at the latter), the ambient light connectors are not there, meaning I would be running new door and dash looms.
So that's what I'm trying to power up the FO emitters manually. But you're saying it's physically impossible? So best solution would be to put my own FO emitters from the AliExpress kit in place with the MB ones are. Thanks Chris.
Old 12-04-2019 | 10:05 AM
we47b1me's Avatar
As long as you cant get the leds to light up you cant do it.
but your ML had ambient light to start with BEFORE you retrofitted COMAND 5 correct? You just went from 3 to 12 colors.
Old 12-04-2019 | 10:46 AM
we47b1me's Avatar
No it was without as so many USA MLs are.
By chance then do you have a wiring diagram of all the looms you installed and the connection points? The only SAM I've seen under the center console is the one that goes to the rear ac controls (which I do not have).
Old 12-04-2019 | 11:46 AM
drwolf's Avatar
RE: chris is banned
You re-did the whole interior panel?
From the pics it looks like the cabin of a GLS but since you dont have the drive mode selector that the GLE/GLS (2016-19) has, looks like you retrofitted the whole interior cabin
Is this correct?
Old 12-04-2019 | 10:55 PM
we47b1me's Avatar
It is rear SAM. Under rear seat.
And I guess to add to Dr Wolf's question -- since your ML did NOT have ambient lighting, you would have put in all new trim pieces with the ambient light tube? So I would not only have to buy a COMAND 5 system and an ambient light kit (such as one from CKM car design), but I would would have to buy the trim pieces as well with the ambient light tubes.
There is an easier way to do this, I know it. The damn MB emitters HAVE to power up another way.
Old 12-06-2019 | 11:51 AM
we47b1me's Avatar
I decided to take apart the light emitter even more, and voila. Got it to power up. For those curious, here's the pinout on the chip:
151 (Brown) - is positive
1DE (Yellow) is Solar (yellow orange color)
19E (Green) is Blue color (polar I believe)
1DE + 19E (yellow + green) fires both (which is neutral, which if I remember from my dad's ML, looks very similar to solar.
I really only care for the solar color, so I'll be wiring it up next to the cigarette lighter which is where my AliExpress footwell lights are wired to.
Old 12-06-2019 | 10:01 PM
we47b1me's Avatar
Anddddd we have retrofitted Ambient Light!!!!
drwolf (12-09-2019)
Old 12-07-2019 | 07:34 AM
we47b1me's Avatar
Well kind of. For 3 color LEDs this work. Not for more color LEDs, Nice to be able to change color and brightness as well. But sure better than nothing. What about the doors?? Blue is truly my favorite.
the doors are next -- before I looked for those pieces, I wanted to make sure it was possible first. The doors will be much easier tapping into power there versus the rigging I had to do for the dash piece. (And still need to get the small piece on the other side of the wheel + cupholders).
Your blue does look really, really good, but I like the solar color just fine, and know I won't have the ability to change to neutral or polar, but at least it matches the rest of the interior.
I can though, change the footwell color as that is the AliExpress kit there.
If anything I debated switching out the trim pieces for that beautiful satin brown ash, which I think you have, since I'm switching out all the trim pieces anyways.
It's not perfect, but it's certainly on the loath to what I wanted 😁
Old 12-09-2019 | 06:07 PM
drwolf's Avatar
Nice work! Post pics of the whole thing then your done. Are you also going to add footwell lights under the front passenger seats?
we47b1me (12-09-2019)
Old 12-09-2019 | 06:08 PM
drwolf's Avatar
That is a really cool shade of blue, kinda more towards purpleish
Old 12-09-2019 | 06:27 PM
we47b1me's Avatar
I actually already added the footwell lights in the front and under both seats (4 in total). Next step is waiting for all the various trim pieces to come in from eBay that I ordered. Switched to Anthracite Poplar, because, why not .
My experiment is now going to entail attempting to take the LED emitters (64 color) from the AliExpress kit I bought, and fit them into the MB housing so it can all be controlled via the android app on my COMAND screen. If that experiment goes awry, and my soldering skills aren't what they used to be, I'll just tap into the door handle light power and everything will be "solar" colored. It's great since those lights turn on and off with the headlights and door opening, and the dash piece will just stay powered on.
Old 12-10-2019 | 10:48 AM
Don_CA's Avatar
ML 350 Bluetec
But....do they flash with music?
Old 12-10-2019 | 02:22 PM
drwolf's Avatar
Show me when you have everything done, or show what you have done so far.
Old 12-23-2019 | 02:28 PM
drwolf's Avatar
any progress? updates?
Old 12-23-2019 | 02:33 PM
we47b1me's Avatar
I was having trouble finding the door trims for the Eucalyptus color I have, but I stumbled onto a set of Anthracite Poplar trims on eBay. It was for a RHD car, but I also found the large dash piece from a separate seller.
Long story short, I have swapped out all the dash pieces for Anthracite Poplar and wired up the Solar color on the ambient light, but I am STILL waiting on the door trim pieces to come from Lithuania 😂. They cleared customs last night, so only a matter of time. But I really do like the black wood versus the standard Brown trim.
Old 12-23-2019 | 04:57 PM
drwolf's Avatar
Cool.. so your just going with solar ambient?
Old 12-23-2019 | 05:02 PM
we47b1me's Avatar
yeah, since it matches best inside the cockpit with all the other colors. Only interesting thing I've noticed is that I have a trim piece from a 2017 GLE, and the LED emitter is the same 2 color led as the ones from the ML's (12-15), but the GLE's are supposed to have the 64 color light. Not a problem, just curious how the GLE lighting works. I know it has to do with COMAND 5, versus 4.7, but from the actual emitter standpoint, I would have figured they would be different hardware. Unless the GLE's you could order them with the regular 3 color ambient light, or the 64 color variant.
Old 12-23-2019 | 05:28 PM
drwolf's Avatar
the W166 chassis of the GLE (16-19) only has the 3 color variant of the ambient lighting, my neighbor has a fully loaded GLE 350W4 and the few times i was able to look it was 3 color setting, Unless you retrofit it, as christheswede has as we saw in the earlier posts. the 2020, from my understanding has the 12 or 64 color variant, but I am not 100% on that and would have to check with GLE section (W167 chassis).
Old 12-23-2019 | 06:04 PM
we47b1me's Avatar
oh wow -- I thought that with the new version of COMAND in the '16-'19 GLE's it went from 3 colors to the full spectrum.
Old 12-23-2019 | 06:30 PM
drwolf's Avatar
my mom has a 16 S550 and she only has the 12 color variant, and its new version of comand so i dont think it has to do with that. Either it comes with some kind of retrofit or you need to get P3 package to have that option.
Old 12-24-2019 | 04:08 AM
black06c230's Avatar
mgLipGD
2013 GL here with 3 color but would love to just swap to another color by replacing the led to the color I want or maybe a RGB led that’s controlled by the controller it would come with.
Can you point me to LEDs on AliExpress that might fit my plan?
Old 12-24-2019 | 11:58 AM
we47b1me's Avatar
Alot of errors here right now.... First of all. 16 S550 aka W222 have 7 colors. Not 12. ALL W166 has 3 colors. ML and GLE! 12 Colors WAS avalible on GLE as an extra option that almost NO ONE ordered.
I know you’re the expert on this, but are you sure about the GLE 12 color option? I don’t see it in the dealer order guide for the 2019’s.
File Type: pdf
Old 12-25-2019 | 03:55 AM
we47b1me's Avatar
Yes. At least here it was. As you also can see in the comand menu. Or it would not be avalible to have it in there.
the only option for it in the COMAND menu is in various retrofits. Have never seen a stock image, let alone the other evidence of seeing GLE trim pieces with only the 3 led color variant, in addition to the ordering guide. I'm not doubting you, have just never seen supporting evidence of it.
Quick Reply: Ambient Light Retrofit / Assembly
