location of auxiliary battery for 2014 ML350 4Matic
. noticed there are multiple videos on you tube about how to replace.
first question is on the 2014 model where is the aux battery located ?
the reason I am asking is because some videos shows it is under the right rear passenger seat where the main battery resides - this seems like a less involved work to replace it.
Some video shows it’s in the trunk and work to replace seems more involved and requires taking off more layers
so I got a bit confused
thanks for your comment.
the main battery for my 2014 ml350 4matic is at in front of the right rear passenger seat. So I am thinking looking at that area first and based on some video once I expose the main battery under the carpet etc. I should be able to also see the aux battery deeper down in the same area
any one in this forum has any other direct experience on replacing a 2014 ML’s aux battery?
thanks in advance
Air suspension, but no start stop.
VIN 4JGDA2EB9EA371367
It is not trivial, but several simple tasks to complete the work. There are some people who cut the cover
, but I would not do it. Here it is (2013 ML350 Bluetec)Last edited by JCM_MB; Nov 2, 2021 at 03:41 PM.
Must be under the front passenger seat next to the main battery. Will have a deeper look and when I change the main (original 7 years!!) I will change the auxiliary.
Regards
Thanks everyone.
I removed spare tire, jack/tools, the bottom trunk liner, and the passenger side plastic trim piece, and stainless inlaid trunk piece… as well as the little cover behind the first aid kit.
the battery is small enough to replace, without removing the big side trunk liner.
It’s just challenging to remove/re-install the metal bracket that holds the battery in.
