Install Distronic Plus ML 350/W166/2013!
Old Jan 20, 2020 | 11:21 AM
stuparu.ionut81's Avatar
ML 350/ W166
Hello everybody. I want to install Distronic Plus on my car!
I have almost everything I bought.
If anyone knows how to do coding, please help me with some information
Of course there are many who want this option.
If anyone else did that, I'd be grateful for some information
Old Jan 20, 2020 | 02:43 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
see this thread:
https://mbworld.org/forums/m-class-w...-lighting.html
and secondly, you are undertaking a huge project, Good luck and post results
Old Jan 24, 2020 | 01:53 PM
ML 350/ W166
Here's everything I bought:
A1665408832 - Distronic cable
A1665454040 - Support ECU
A1664401432 - Sensor Cable / Rear Radar
A1665404907 - Front Sensor / Radar Cable
A1665403710 - Multifunctional Camera Cable
A1664405513 - Blind Spot / Distronic / Band Maintenance Cable ...
A0009004701 - ECU Sensors / Radar
A0009057402 - Multifunctional Camera
A2129050751 - Light Block
A1669009407 - Steering Column Module / Distronic Control
When I start the installation, I come back with news.
Old Jan 24, 2020 | 04:09 PM
drwolf's Avatar
You're also going to need the front grille thats compatible with distronic plus
Old Jan 24, 2020 | 10:37 PM
ML 350/ W166
Yes, it is, someone already has it, I just have to order it
A1648880411
Brake pump not sure if it is compatible, if anyone knows how to tell me, please?
Old Jan 31, 2020 | 11:56 PM
ML 350/ W166
And start the party
I'll put the cables in their place
In 2 days it must be finish!
Old Feb 2, 2020 | 03:33 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
And?
Old Feb 3, 2020 | 02:22 AM
ML 350/ W166
I still have to install...
Today I can finish, I thought it was simple..
I was greeted with many errors,I managed and got rid of them for a moment
Besides Distronic, we also installed the rear camera, ecu RDK wheel pressure monitor, trailer towing system,Blind/Spot,multifunctional room...
I'll have to put radar sensors on the back bar
I had work to do
Keep you up to date!
Old Feb 7, 2020 | 01:41 PM
ML 350/ W166
I have finished installing everything.
I have problems with coding
@jrsmith_68,it seems he doesn't want to tell us anything.
I hope to succeed
Old Feb 16, 2020 | 04:08 AM
ML 350/ W166
I also solved with coding.
Distronic Plus Works well.
Old Apr 2, 2020 | 11:25 AM
ML 350/ W166
Finally I'm done.
Successful project, without errors and perfectly functional.
Old Apr 3, 2020 | 10:52 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Im really impressed with your achieving this complicated goal and envious. Come to Illinois and install the all around camera system and backup alarms on my ML
Old Apr 4, 2020 | 01:22 AM
ML 350/ W166
It's complicated to come there. I'm already out of my country.
I'd go anywhere in the world, where I'd have a stable financial and quiet place.
Old Jul 3, 2020 | 09:24 PM
MbAndy's Avatar
Gl w166
Could you help me with this project, I want to install distronic plus on gl 2015 w166
Old Jul 5, 2020 | 01:25 AM
ML 350/ W166
Originally Posted by MbAndy
Could you help me with this project, I want to install distronic plus on gl 2015 w166 , please help i am from România
Hello. You can contact me in private and see what can be done!
Old Jul 6, 2020 | 02:04 PM
drwolf's Avatar
Nice work! how much money did you put into it? also can you post pictures of the car with the retrofit?
Old Jul 7, 2020 | 07:33 PM
MbAndy's Avatar
Gl w166
I don't know why but I can't contact you in private, the forum has errors, could you please start the private conversation first?
Old Jan 6, 2025 | 03:17 PM
discme91's Avatar
2026 GLB250, X3 M40i
has anyone else tried this and succeeded? What software is used for coding new modules? Thanks
Old Jan 6, 2025 | 03:28 PM
drwolf's Avatar
You might wanna contact the user above who did it.
Old Apr 5, 2025 | 08:44 AM
Puddinkie22's Avatar
Hello, i am looking for A0009004701 where it is located, could you tell me?
Old Apr 5, 2025 | 11:12 AM
trigital's Avatar
W213 All-terrain
If you have Xentry, you can follow the step by step guide for diag, also on the top right corner you can find a blue small book, this will open even pictures.
Old Apr 5, 2025 | 02:00 PM
I dont have xentry 😅 thats why i ask.
Old Apr 5, 2025 | 04:06 PM
trigital's Avatar
W213 All-terrain
If you don't have Xentry, why you ask about this module?
Old Apr 5, 2025 | 05:58 PM
i just asked where it is located in the car... if i had xentry i didnt had to ask... but why i want to know is because my nr 116 fuses blows.. and this is from the radar sensor etc.
when i disconnect the front bumper radarsensor it still blows.. so i like to know where it is, so i could disconnect the module and test the fuse, if it still blows its in the wiring harnes.
Old Apr 5, 2025 | 06:22 PM
i think i have found location of the module on the forum of a GL, looks like its behind OBD connector and left of the brake padle. i have to look tomorrow how it goes.... also have question about wiring harnas, does this cable go behind the radioscreen unit?
