Oil leak from transmisson 722..
regards
Norway
If the oil is from the driveline, you need to narrow it down to the:
- front axle
- transfer case
- transmission
To me it looks like the oil is coming from the front propshaft seal.
If the fluid is clear, and does not have a strong smell, it is transfer case oil. Do you agree? What is your next step to confirm the diagnosis?
Addressing a leaking transfer case can be done by replacing the case with a rebuilt one, or resealing the unit you have. In both options, the transfer case needs to be removed.
The leak can be coming from the transmission oil pan or the input shaft seal on the transfer case.
