Ml 350 tyres for soft ride
Seems Michelin Tour HP are favourite from some owners but my dealer says I have to have 107 W, whereas the contis are 103 W. I will never do 149 mph with 975 kilos on board!
Will the 107's give a firmer ride than 103's? I am not concerned about price or mileage, I simply want the softest ride over our rubbish UK roads
Any thought please?
Seems Michelin Tour HP are favourite from some owners but my dealer says I have to have 107 V, whereas the contis are 103 W. I will never do 149 mph with 975 kilos on board!
Any thought please?
I presumed that if the load index is greater then the tyre must be stiffer? Is that not correct?
I'm on 19" rims running at 32 psi
The Continentals that I had on my ML were probably the worst tires I've ever had on any car (in more ways then one). Michelins with the proper SUV load rating are a definite step up in terms of handling, wear, noise and ride comfort. If you want all-seasons, my top choice by far would be Michelin CrossClimate SUV tires that come in the required 255/50ZR19 107Y XL size and spec. I'd also stay away from Pirellis - they grip well at first, but like the Contis they get hard and noisy and don't wear evenly.
However I can only find the tyres I would prefer (michelin latitude tour hp) in 107W or 103 V.
As I want the softest ride would 103V be ok? (we have a 70mph limit ! )
The speed rating is different from the load rating, and a V speed rated tire (240 km/h / 149 mph) is certainly fine - but again, keep in mind that the speed rating is only applicable when the tire is at the recommended pressure.
The info is taken from page 307 of my manual supplied with the car for the" Ml 350 Blue Tech 4 Matic" 255/19/103W Under "Summer
tyres", although for Winter tyres it specifies 107 H XL m+s?
Thanks for you input
Do I take it that 103V is unsafe. Can't seem to get any sense from MB
Do they have a tech contact site?
Thanks again
Fitted 4 Michelin Latitude Tour HP on my 2014 ML350
Vehicle is transformed! Ride is now smooth, soft and quiet .It's a different car with the Continentals gone.
If you want a better ride for you Ml, don't hesitate, worth every penny, if you can find them!
Thanks to all who suggested them.
Higher load WILL ride stiffer, given the same-same model tire.
Every brand makes good and bad models.
Avoid tires made during Covid...like the plague.
105 load, like 245/60-18 carries over 2000lbs each, the ML is 6000lbs 103 load is very close behind, over 1900lbs each tire.
I have a set of Kumhos in 255/55-19 going on. Consider a larger size like this for comfort, price and durability. When comparing different size, like the 245/55-19 I tried, just look at the (standard) load of both tires. A taller, but mostly higher load will ride and last better. The stock 255-50-19 are kinda lame in my book. IDK if UK....you can use different sizes, lol.
