Do I need to fix the dent and paint?
Old Oct 5, 2021 | 01:09 PM
Issac2021's Avatar
ML350
When I reversed the car, the fender of the car scratched against the iron pillar. I found that the fender is slightly dented and the paint is damaged(about 5 cm). Do I need to repair it quickly to prevent corrosion? How much is estimated?
Old Oct 5, 2021 | 02:22 PM
chassis's Avatar
2017 GLE350 4MATIC
It’s your choice. If the damage does not cause functional problems, in theory you can choose to not repair it, ever.
Approx $1500 to respray one panel, depends on the shop and the location (city).
Old Oct 5, 2021 | 02:26 PM
Issac2021's Avatar
ML350
Thank you very much.
It's really expensive...
No any functional problem. I just want to fix it myself. I have got the same color paint. However, I am wondering whether it lead to metal corrosion.
Old Oct 5, 2021 | 06:47 PM
Issac2021's Avatar
ML350
I found a used one which is no any scratch and the same color. Maybe I can change it. Much cheaper than respray.
Old Oct 6, 2021 | 09:05 AM
Leetom's Avatar
2013 ML550 US spec. Air+Offroad pkg
Is Zinc layer compromised?
Rust should only be an issue if the scratch goes down to base metal past the zinc coating. If you are in dry climate and there is no ocean salt air, and they dont heavily salt the roads, should be fine (so long as base metal isnt showing). You could just touchup paint if base metal is exposed to seal against rust.
Old Oct 6, 2021 | 09:09 AM
Issac2021's Avatar
ML350
There is black color turned out at the scratch/dent place (diameter about 0.8cm). I checked the left front fender was made with aluminum. Maybe I don’t need worry about the corrosion so much.
Old Oct 7, 2021 | 11:31 PM
hutch300's Avatar
2022 GLE450
If you have these questions I'd say its best left to the pros or left alone.
Old Oct 9, 2021 | 11:13 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Have a person who does pointless dent removal pull the dent out and then use rubbing compound and if needed get a paint touch up kit from dealer Should cost about 200 dollars. I have done this with numerous cars. No need to have the whole fender repainted or just leave it.
Old Oct 9, 2021 | 11:30 PM
Issac2021's Avatar
ML350
Thanks a lot for your nice suggestion. I am trying to do it myself.
Old Oct 14, 2021 | 07:56 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
I was also going to say I knew a few inexpensive places you can go to if your in the southern california area. PM me if you want to know details.
Old Oct 15, 2021 | 03:11 PM
Issac2021's Avatar
ML350
Thank you man. But I live in Philly. It's quite far from California
