New Battery Recommendation
Old Nov 13, 2021 | 02:14 PM
keman58's Avatar
2012 ML350 Bluetec
Hi Folks,
Looking for advice on which battery that you would recommend for a 2012 ML350 Bluetec. We still have the original battery and never had a problem however it’s Tim I change.
Thx in advance.
Old Nov 13, 2021 | 02:42 PM
chassis's Avatar
2017 GLE350 4MATIC
OEM from a dealer.
Old Nov 14, 2021 | 08:54 AM
Barry45RPM's Avatar
2015 ML 350
You can by the exact same battery with the OEM supplier manufacturer's name on it thru the road service contractor that MB uses. Lower battery and installation costs too. Same exact battery and spec AGM that MB uses, but the Dealership's is branded MB.
Old Nov 14, 2021 | 10:35 AM
rmesola's Avatar
2014 ML350BT
Any h8 agm will do. I buy the walmart platinum brand with 4 year warranty
Old Nov 15, 2021 | 01:15 AM
Babukb2's Avatar
ML350
Costco has the Energizer H8 AGM
you know Costco is great for warranty, and that battery even has a higher CCA rating than the OEM one. Almost half the price of what it will cost you at Mercedes for their battery.
Old Nov 17, 2021 | 03:48 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
how do you do this, do you have to have Mercedes Road side service. Need more info
Old Nov 17, 2021 | 06:11 PM
Barry45RPM's Avatar
2015 ML 350
T the time, I did. The car was about 2 months away from my extended warranty expiring, (Battery was on me $) But again, and mercedes repair indy can do this for you.
Old Nov 18, 2021 | 06:58 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
As well, I believe you don't have to have the new battery "coded" to the car ECM like BMW does.
Old Nov 19, 2021 | 11:17 AM
Babukb2's Avatar
ML350
i dont know if @keman58 's 2012 is identical, but i can confirm no coding was required for my 2014. Also, i didnt lose any settings, which is odd because everywhere i have read and watched videos they advise to externally power the car to maintatin all your settings when replacing the main battery. I pulled both main and aux battery, so the car sat for a while with 0 power. Once i got the batteries back in the only thing i really lost was the trip mileage and mpg information, everything else was still there. Radio favourites, car settings and anything else i checked was retained.
