2015 ML350 M276 Cam position sensor problem
Active codes are :
P13B2 - MB specific code which im not sure what it is. my scan tool just says see manual
P0368 -Camshaft Position Sensor "B" Circuit Low
P0364 - Camshaft Position Sensor "A" Circuit Low
P2088 - A Camshaft Position Actuator Control Circuit Low Bank 1
P2090 - B Camshaft Position Actuator Control Circuit Low Bank 1
Pending codes for cyl 1,2 and 3 missfire/ coil pack. (to be expected with cam issue)
I pulled the bank 1 cam position sensors and plan to replace one or both of them tomorrow. The intake one has some oil bypassing the connector.
None of the cam adjustors have any oil leakage.
Thoughts on this being simply just a bad cam sensor? Why would i have codes for A and B sensors? I assume A is intake and b is exhaust cam.
I thought about replacing both bank 1 cam adjustors as well but dont want to just throw parts at it.
Clearing the code and starting the car i just get P13B2 active and then the first 2 for cam sensors come back after a min.
As it turns out i had the #1 coil pack (less than week old) fail and short internally blowing the #217 fuse which happens to run power to engine controls like cam adjustors and cam position sensors..
Replaced the 20amp fuse, started the car and got a big puff of smoke, the coil shorted through the side and arced out on the motor. this is when i caught that it was a bad coil causing the blown fuse.
Replaced fuse again and put in an old 110k mile coil and car runs good again.
This is the second time i had a Beru coil go bad within a week of use. Not sure if there is a bad batch that FCP euro has or if i have an engine ground issue that will show itself in a few more weeks.
Time will tell.
Time will tell.
ANyone have engine ground location that the bank 1 could would use? Might as well clean it up for good measure.
did you replace the coils too or just the connectors?
mine was evident visually as it arced through the exterior and to a screw on the valve cover.
updated ones are Bosch.
Fcp refunded them and I replaced with ones from the dealer which were of a superceded part number from the AMG motors and is made by Bosch. Haven't had any issues since.
I had one of my sensors with slight oil seepage when i was diagnosing our ML, replace it for peace of mind. Checking the cam sensors for oil leak should probably be added to the 100k mile maint checklist IMO.
