Drivetrain Vibration
Old Jun 28, 2022 | 11:28 AM
danrob's Avatar
2008 ML320 CDI
Question Drivetrain Vibration
Hello, I drive a 2015 ML350 Bluetec and I have developed a vibration in the drivetrain.
I originally thought I had a brake or tire issue. The mechanic check it, took it for a test drive and said everything was good. My experience has been that when I drive it long distances in warm weather there is a vibration that develops and gets worst the faster you go.
I am planning on changing the transmission fluid as a first step. Can anyone suggest or provide your thoughts on what is causing this problem. My concern is that this may lead to other issues if I don't address this.
Thank you in advance for your comments and feedback
Old Jun 28, 2022 | 01:16 PM
chassis's Avatar
2017 GLE350 4MATIC
More diagnostic work is needed.
- what speed does the vibration occur? All speeds or certain speeds? Does the vibration change with speed?
- does braking affect the vibration?
- does steering (lane change) affect the vibration?
- do you have vibration at idle in park? Or at idle in Drive?
What is the history of this vehicle? How many miles are on it and how long have you owned it?
Old Jun 28, 2022 | 01:35 PM
danrob's Avatar
2008 ML320 CDI
Hi, please see my comments below:
When the vibration begins, it is at 60 - 65MPH and continues even when I slow down
Braking does not effect the vibration
Steering does not change the vibration
Vibration is only apparent when the vehicle is being driven
The vehicle has approx. 135K km (84K miles). I have owned the vehicle since 2016
Thank you,
Old Jun 28, 2022 | 02:10 PM
threeMBs's Avatar
Only MBs - the best or nothing
This is the "ideal" speed at which vibration due to wheel/tire imbalance reveals itself. Were new tires installed recently or wheels rotated? If yes, Road Force Balancing (on a special balancing machine) will likely cure the issue.
Old Jun 28, 2022 | 05:46 PM
chassis's Avatar
2017 GLE350 4MATIC
Agree with @threeMBs
The description sounds driveline related:
wheels
Tires
brake rotors
propshafts and flexible couplings
halfshafts
What seems like the cause in your view?
Old Jun 28, 2022 | 05:47 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
cv axle
Do you feel it in the steering wheel or in your seat?
Old Jun 28, 2022 | 10:25 PM
Etienne Lau's Avatar
Ml350 bluetec
Try rotating the wheels/tires. It's a cheap/free easy troubleshoot to see if that makes any difference.. Does the steering wheel oscillate left and right?
Old Jun 29, 2022 | 10:37 AM
danrob's Avatar
2008 ML320 CDI
wheels
Tires
brake rotors
halfshafts
Hi, while I am not a mechanic I have replaced Tires & Brake rotors. The Wheels are BBS.
This leaves the last two. Would the wear/damage be visible by a mechanic??
Thank you
Old Jun 29, 2022 | 10:38 AM
danrob's Avatar
2008 ML320 CDI
Thank you, will get the tires rebalanced
Old Jun 29, 2022 | 10:39 AM
danrob's Avatar
2008 ML320 CDI
The steering wheel does not oscillate.
Old Jun 29, 2022 | 11:46 AM
Ml350 bluetec
@danrob This still could be anything:
  1. Driveshaft
  2. Worn suspension bushings
  3. Lower control arm bushings
I doubt it's transmission related, ie you suggested changing the transmission fluid, while it's a worthwhile maintenance item, I would not anticipate that as the cause.
Old Jun 29, 2022 | 11:55 AM
danrob's Avatar
2008 ML320 CDI
  1. Driveshaft
Thank you Etienne, I will have the mechanic look at these items.
Cheers,
Old Jun 29, 2022 | 12:01 PM
Ml350 bluetec
@danrob I did have 2011 VW Touareg TDI that also vibrated at speeds in your range. And it was a known issue with that vehicle. VW Issued a TSB and if you followed the TSB carefully the issue was resolved. But the suggestion further up about having the tires balanced is also a good suggestion as well. The VW Touareg also had prop-shaft/drive shaft that also would vibrate as well if the flex plate was worn out and the resolution was to repair/replace the flex plate.
So you really need to find a good Mercedes mechanic that knows that they are looking at on this one. DO NOT take it to a general mechanic that knows nothing or very little about Mercedes.
Old Jun 29, 2022 | 12:33 PM
chassis's Avatar
2017 GLE350 4MATIC
Thank you
Are confident the tires were balanced properly and are not damaged now?
Do you think a wheel is bent?
Failed propshaft flex couplings will be visible to an experienced mechanic. Failed axle shaft boot will be visible to a mechanic.
Failed propshaft or axle shaft joints need some diagnostic work (road test) that a mechanic is able to find.
Old Jun 29, 2022 | 04:01 PM
danrob's Avatar
2008 ML320 CDI
Etienne, thank you for the support. I have made an appointment to bring it into my mechanic. He specializes with MB and I am fairly confident he can find the problem especially with the some of the suggestions you have made.
Thanks again, much appreciated.
Old Jun 30, 2022 | 06:57 AM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
While BBS generally makes great wheels, are they hub-centric for this specific application (66.6 mm)? I've had high quality aftermarket wheels cause this simply because they had incorrect or crappy plastic centering rings.
Old Jun 30, 2022 | 09:20 AM
danrob's Avatar
2008 ML320 CDI
Honestly I don't know. I do know that there are no plastic centering rings.
Old Jun 30, 2022 | 09:56 AM
Diabolis's Avatar
Next time the wheels are off, have a look on the inside of the wheel centers (hub bores). BBS wheels should have am aluminum centering ring and a steel wire retaining ring that holds the centering ring in place. The hub bore should be clearly marked on the aluminum centering ring - it needs to be 66.6mm.
I've had this happen numerous times with aftermarket wheels that are not perfectly centered on the hub. Mercedes uses hub-centric wheels so the wheel bolts do not center the wheel - they only clamp it down. If the wheel is not perfectly centered on the hub, you'll get a vibration.
Old Jun 30, 2022 | 10:00 AM
danrob's Avatar
2008 ML320 CDI
Thank you, I will have the mechanic check this.
Much appreciated
Old Jul 2, 2022 | 09:33 PM
Ml350 bluetec
@danrob In parallel with what @Diabolis is saying. The VW Touareg TDI had similar vibration and was solved when VW issued a TSB. The TSB contained detailed instructions on how to properly mount wheel back onto the vehicle. The procedure required using the wheel bolts and wheel hanger in a particular sequence to make sure the wheel was centered on the hub. I did not believe the TSB when I first saw it come out, but I had the vibration. So I reluctantly one weekend repeated the steps on all 4 wheels. And I could not believe it, but after following the proper steps on the TSB to center the wheels on the HUB, the problem went away.
Old Jul 3, 2022 | 04:14 AM
robfolland's Avatar
ML63 W166
danrob, interested to know your outcome, i have a similar problem and suspected it is the center bearing mount. i had replaced all the tyres etc and the vibration remained, SOLUTION WAS. the coupling to the grearbox was loose
Old Oct 1, 2024 | 10:35 AM
Potrice's Avatar
2013 ML350 Bluetec, 1966 Ford Mustang Convertible (sold)
Much appreciated
Did you find out what the problem was?
Old Oct 1, 2024 | 06:36 PM
robfolland's Avatar
ML63 W166
Hi , yes, after the installation of another drive shaft and that did not fix the problem, i changed a couple of tyres which didnt solve the problem,
eventrally ballanced the new tyre (michilin) that had bene fitted and that was the problem. a very expensive journey to find the fault of a new tyre not correctly ballanced. (and i recall im sure i had that tyre reballanced as part of the diagnosis process)
Old Oct 2, 2024 | 09:16 AM
danrob's Avatar
2008 ML320 CDI
Turned out I had a couple of issues;
1 - my right front wheel was out of round caused from being run off the road
2 - left front brake caliber seized. Had to replace the caliber, both rotors and replace the pads.
No issues since then.
Old Oct 2, 2024 | 06:44 PM
robfolland's Avatar
ML63 W166
Great to hear you resolved the problem.
