Wheel llug but replacement
If you want to reengineer a hub and bearing with a machine shop, yes.
There are no lug nuts on a Mercedes, but rather wheel bolts.
Don’t go down this path, you won’t enjoy it and it will end poorly for you.
You know about the wheel installation tool, correct? It’s made for the very purpose you are writing about in your posts.
You can buy one from Amazon for under $10 like one of these
or for about $3 directly from AliExpress like this one
https://www.aliexpress.com/item/4000173756744.html
You just need a wheel centering pin with a M14 x 1.5 thread pitch.
^ This.
https://www.amazon.com/Black-Wheel-H.../dp/B07RP35KJJ
https://www.amazon.com/1pc-Steel-Whe.../dp/B00MWAQGSQ
Yes, one of those pins will do the trick. I've been around cars and people wrenching on them for most of my life and I erroneously assume that everyone has seen the same things and tricks that I have and that they ought to be obvious, but that is definitely not the case. Sorry - and cheers!
Yes, one of those pins will do the trick. I've been around cars and people wrenching on them for most of my life and I erroneously assume that everyone has seen the same things and tricks that I have and that they ought to be obvious, but that is definitely not the case. Sorry - and cheers!Re the distances, my wife is indochinese and the first time I took her on a trip was from Melbourne to Darwin, about 4000 kilometres, and she found out fuel stations, towns and even houses can be 500ks+ apart both her and her family freaked out.😂🤣 Like many other places around the world 100 kilometres is a big trip. When I was in Tasmania a trip to work each day was a 600 kilometre round trip.
