2013 Mercedes Benz ML350 4Matic W166- Rear Coil Spring Removal and Installation..
Old Feb 11, 2023 | 11:27 AM
awbooth's Avatar
2013 Mercedes benz ML350 4Matic
Has anyone removed broken rear coil springs on a 2013 ML350 4Matic W166 chassis? If so, what was your process? Thx so much!
Old Feb 13, 2023 | 11:22 AM
dvakata's Avatar
ML350d w166
Last week I went to my local indy shop and they did it in one hour. Cost me $385CAD including Bilshtein springs. I would never do it myself seeing how 2 experience techs and bunch of tools did it.
Old Feb 13, 2023 | 11:38 AM
awbooth's Avatar
good idea! It might be worth hiring someone to do it! Thx
Old Feb 13, 2023 | 10:36 PM
GLK Super Fan's Avatar
GLK250 ML350
https://mbworld.org/forums/m-class-w...ml#post8690951
Post number 181, I documented how I did it and tools I used.
Old Feb 14, 2023 | 06:40 AM
awbooth's Avatar
Thank you! Appreciate your help! 👍
Old Feb 14, 2023 | 05:49 PM
awbooth's Avatar
I reviewed your post. Very helpful. Just to recap, I'm the person replacing my rear coil springs on a 2013 Mercedes ML350 4Matic W166.
1st Question:
Is it necessary to disconnect the control arms to remove the coil spring?
I ask because it seems as though if you correctly compress the spring using the kit you showed in your thread that the spring should close enough to remove from the car without disconnecting the suspension? Now I could be completely wrong, I just wanted to ask.
2nd Question:
Did you need an alignment after the new coil spring installation? I ask because with that many pieces of suspension disconnected did the alignment get out of alignment.
Thx again!
Old Feb 15, 2023 | 11:37 PM
GLK250 ML350
1st Question:
2nd Question:
Thx again!
You can try to remove fewer control arm, but you just have to compress the spring more. I don't feel safe to overly compress the springs, but u may feel more comfortable than me.
No need alignment, none of those arm affect alignment
Here is the video I used
Old Feb 16, 2023 | 06:02 AM
awbooth's Avatar
This is great! Thx again!
Old Feb 20, 2023 | 05:24 PM
awbooth's Avatar
Hey Man! I wanted to give you an update.
I took on the project today. I followed your instructions and added a few pointers.
I didn't use the coil spring compression tool to remove the old coil or install the new coil.
I disconnected the lower shock mount bolt, lower sway bar link, both upper control arms, disconnected all wiring around the caliper, plastic wire mounted brackets that clicked into the control arms. I was able to lower the entire area enough to safely remove the old coil spring and factor in the new coil spring. NO COIL SPRING COMPRESSION TOOL NEEDED.
It took some muscle to bounce the lower control arm low enough to sneak in the new coil spring as there is the upper and lower plastic mounting pieces that need to screw onto the upper and lower part of the new spring coil.
Honestly, if you disconnect every single brake line bracket and abs wire brackets you shouldn't have to remove the caliper /brake pads. Prior to lowering your jack from under the shock mount be sure all wires are free because if you lower your jack too fast there is a possibility of damaging a brake line, abs sensor wire etc. etc.
Each side took me 1 hour as I'm super **** with checking my work and taking my time.
I just wanted to thank you for responding to my forum question as it was your response that gave the boost/confidence I needed to take on the project myself.
Appreciate you!
Old Sep 7, 2023 | 06:25 PM
Yurii's Avatar
ML 350Blutec
"Last week I went to my local indy shop and they did it in one hour. Cost me $385CAD including Bilshtein springs. I would never do it myself seeing how 2 experience techs and bunch of tools did it"
Dear Dvakata, can you share the contact or phone number of a local indie store, otherwise I have the same problem with springs
Old Nov 28, 2023 | 10:16 AM
Oldbobsgarage's Avatar
2013 ML350
Here's an additional video with more detail on changing rear springs on a 2012 to 2019 W166 (ML350).
Old Mar 4, 2025 | 05:40 AM
JohnW166W204's Avatar
W166
I Am hoping to try and get them done the weekend. I will let you know how i get on. bob's video is very useful
