strange and mysterious vibrations ML250
Old May 23, 2023 | 08:32 AM
ponzio16's Avatar
w166
Good morning everyone,
I've been battling for some time with vibrations that seem to come from the front while the vehicle is underway, especially as the speed increases and they tend to decrease as I accelerate.
I took it to mercedes several times, I initially replaced the engine mounts, then the front shock absorbers (without shock absorber mounts because they were unobtainable), with the replacement of the shock absorbers the situation improved but did not disappear, according to the mechanics (both mercedes and others 2 generics) everything seems to be ok, but this vibration that seems like a sort of pitching persists.
This remains even if the vehicle is placed in N while travelling.
Has something like this ever happened to you?
Old May 23, 2023 | 06:56 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
How old are your tires? What happens if you rotate them front/back?
Old May 24, 2023 | 01:38 AM
ponzio16's Avatar
w166
I didn't write it, however the tires are new (changed for the occasion) and the rims are ok
Old May 24, 2023 | 08:38 AM
2013 ML350 Bluetec
Cv axles?
Old May 24, 2023 | 08:41 AM
ponzio16's Avatar
w166
what it means?
do you mean the transmission shaft?
Old May 24, 2023 | 03:14 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Old May 25, 2023 | 01:43 AM
ponzio16's Avatar
w166
ok, but in this case when the car is moving, and I put the shaft in N, it should do nothing, instead also in N the machine continues to vibrate. Can be?
Old May 25, 2023 | 09:11 AM
JCM_MB's Avatar
Careful here. You put it in N, neutral, and the car riding along the highway/street? If there is a problem with any of the axles: CV axles, or transmission shaft, they are still rotating --> Any unbalanced rotating component under load or not WILL vibrate.
Now if the car is in sitting on the street/driveway, and set to N, I would not expect any vibrations; however, there have been reported cases of vibrations on the W211 (several threads on that) in N after replacing CV axles for non-MB parts.
Many years ago, @1997, I had a subtle vibration on a Toyota Corolla (@30K miles), the dealer could not reproduce it and blamed it on the tires. Front tires were replaced, and the dealer insisted it was all good. It took me some talking back and forth (and several visits) until their master mechanic (the "boss") accepted to ride along with me (I was driving) to reproduce it in just 5 min. Summary: slightly bent front right CV axle. He could not understand what was wrong with it, but the new one never vibrated (finally went to the junkyard 15 years later)
Old May 25, 2023 | 09:52 AM
ponzio16's Avatar
w166
Thanks, now I'm looking at taking it to the mechanic next week and I'll let you know
Old Jul 9, 2023 | 11:11 AM
mike919's Avatar
86 190E 2.3, 2014 ML350 Bluetec
Any updates on this? I'm having a vibration between 112-119km/h. All wheels have been road force balanced.
Old Jul 10, 2023 | 09:22 AM
ponzio16's Avatar
w166
unfortunately the mechanic is busy, we'll talk about it again after August
Old Oct 19, 2023 | 03:19 AM
ponzio16's Avatar
w166
I took the car to the mechanic, according to him the vibrations were coming from the rear and he replaced the rear shock absorbers, the vehicle runs better, but I still don't feel satisfied, I feel roughness
