W166 Upgrade Wireless CarPlay&Android auto carlinklife
Old Jan 22, 2024 | 05:40 AM
Carlinklife's Avatar
Former Vendor of MBWorld
Upgrade Wireless CarPlay&Android auto to your M-Class (W166) 2012-2015
Our Apple CarPlay/AndroidAuto integration kit will give you the ability to add-on functions for Apple CarPlay and Android Auto to your Mercedes’s existing entertainment system.
To control and switch the apps within Carplay, it is integrated with your vehicle’s knob controls and original touchscreen.
Or you can control it with your voice thanks to Siri/Google Assistant.
You will not lose any functions from your original system, the integration kit will work as an added function.
The kits will come with the required module and all the necessary wires to complete installation in your vehicle.
Version 2 Improvements:
– No need for a separate Microphone for Siri/Google Assistant as the kit uses Original microphone
Wireless AndroidAuto is now supportedFeatures of our kit:
– Wired/Wireless Apple CarPlay
– Wired/Wireless Android Auto
– Easy control with vehicles built-in controls
– If your vehicle has original Rear View/Surround View cameras, those will continue working the same way
– This module can be extended with Front/Rear view camera (if your vehicle didn’t come with those originally from the factory)
– The installation is completely plug & play and 100% reversible.
– Supports touch screen.
LINK:https://carlinklife.com/products/wir...reverse-camera
Enjoy $30 OFF + Worldwide Free shipping ! (USE CODE: mbworld )
Only for mbworld forum members!
Old Jan 22, 2024 | 11:46 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I'm interested.
Is there an installation how-to link I can peruse to see what I'd be getting into if I order the system?
Am I correct in thinking that ALL factory functions will remain untouched, and one can toggle between the OEM display and the AA upgraded display?
I have an android; I'd be looking for the wireless version of Android Auto; this unit has that feature?
Wife has an Apple; can the unit toggle seamlessly between AA and Carplay?
Old Jan 23, 2024 | 04:58 AM
Originally Posted by rapidoxidation
I'm interested.
Yes, it supports wireless Carplay and wireless Android Auto, and all original features can be retained. The switch between the Mercedes system and the Carplay system can be easily achieved by long pressing the “back button” for 2 seconds.
Old Jan 23, 2024 | 05:00 AM
I will send you a detailed installation video. Please contact our support email:support@carlinkitlife.com
Old Feb 23, 2024 | 10:54 AM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
I'm interested.
did you end up installing this?
Old Feb 23, 2024 | 01:36 PM
2013 ML350 Bluetec
I'm still planning on it but it might be another few weeks. Funny how life keeps getting in the way!
I will be reporting back on my results though. Stay tuned...
Old Feb 23, 2024 | 04:16 PM
eddieo45's Avatar
lol, I'm always amazed at how busy I am with all kinds of nonsense*! I don't mind telling you that I did not want to DIY this module; I've done tons of interior MODs and repairs over the years - head unit swap, install OEM Bluetooth, replace window switches, door handles, HVAC controls, steering wheel buttons - but I feel like I'm getting too busy and too old/tired, plus I have more money than I used to! So, I reached out to a couple of local car audio places and I figured if they could do the job for $500-$600 I let them handle it. BOTH places quoted me $850-$900 for the hardware and $250-$500 for the labor! The install video that Andy from Carlinklife sent me is just over 7 minutes and it's barely speeded up! If it takes me two hours to do it in the ML it'll bebecause I ate lunch while doing it!!
*You would not believe how much time and energy (and a little bit of $) I have invested in phone mounts!! I think I may finally have the ones I want, just in time to install Apple Carplay and not need to see the phone anymore!!
Please do!
Old Mar 9, 2024 | 11:40 AM
Mattmiller1973's Avatar
G500, GLS450
Any updates from someone who has installed?
Following.
Old Mar 9, 2024 | 12:52 PM
eddieo45's Avatar
This is the installation video.
https://drive.google.com/file/d/1X3c...w?usp=drivesdk
Old Mar 16, 2024 | 08:56 PM
Qikslime's Avatar
ML63
Hi all. I bought one of these back at end of January when the promo code was sent out. Took me a while to get around to installing it, but yesterday I got it done. Here's some info. (Installed in an ML63 over the ponds in Australia).
The install is relatively straight forward. Somone more dextrous than me could probably have it all done and configured in an hour or so, but i would anticipate you will need at least 2-3 hours to read everything, watch the videos, and take all the steps carefully. The hardest part for me was trying to get the head unit back into place with all the wires behind it. That was about 40 minutes on its own!!! But for some that might end up being 2 minutes.
Very important. Read the instructions that come with it first. There is a page about setting dip switches on the unit itself. Make sure you do these.
Then follow the video instructions. My unit was slightly different as I guess they have updated it a little since the video, but you will be able to work it out easy enough if you follow along slowly and carefully.
Once all was finally connected and in place, I went into the engineering menu as per the video, made the changes, turned off the car and went away for 40 mins and came back and turned it all on. I did the connection following the instructions re bluetooth etc and it all seemed to be set to go.
Initially I couldn't hear anything through carplay and I thought i had the dreaded sounds not working issue that many have experienced with these types of things, but after a few minutes and checking and double checking etc, i tried turning the volume right up and I could hear the sound, but it was very quiet and distorted. In the manual it says, that if this happens, connect two of the ground wires to each other (they show you which ones in the manual) and so i tried that and it was then working more like it should.
Carplay came up and started working fine. Note, it is not touch screen, so if you want that, you will have to look for other options. Everything is controlled by the Mercedes dial controller on the console. The volume buttons on the steering wheel work as do the phone buttons. However, the track forward and back buttons on the main head unit next to the main volume dial, do not work for track forwarding and back which is kind of annoying as I used to use them a lot.
My car has the AMI port in the central console storage box, so I had to run the aux cord to the AMI cord (all supplied) from the head unit back to the centre console. I have yet to decide how to make this neater, but at least it is all working.
You have to select AUX on the head unit to have sound from car play, and there is a notable difference in sound output, which can be improved, by selecting Sound on the Mercedes NTG screen and choosing Boost. However this brings a lot of noise into the system which you hear between tracks and for some this might be quite annoying.
When getting into the car and turning car on the system takes about 10-15 seconds to come on, but if you were previously on car play the last time you turned the car off, it does go back to where you were and the track you were previously playing will be there and on pause (which i like, as opposed to it just starting to play).
So for the $260 or so that it cost, i would say it is a good result. Easy enough install, mostly good instructions, and a relatively good outcome overall.
I cant stress enough though, if you buy one of these, follow the instructions in both the manual and the video carefully and slowly and dont rush or shortcut anything and you should be fine.
Hope this helps someone in their decision process.
David
Old Mar 17, 2024 | 03:26 AM
fanfan's Avatar
2007 CLK550, 2014 ML350
HI,
My original Unit doesn't work on my 2014 ML350. It doesn't turn on. The on button light keeps on flashing but nothing in the unit will work, therefore not sending image to the screen. Will your solution work on despite this issue ? if not what else could you recommend ?
Old Mar 18, 2024 | 06:45 AM
Qikslime's Avatar
ML63
I dont really know myself, but if your original unit doesnt turn on you wont be able to select AUX and you wont be able to get to the engineering menu, so I cant imagine anything like this would help you. Maybe you'll have to buy a head unit from a wrecker or something. Maybe go to a car audio store and see what they can do. I am not sure. Good luck.
Old Mar 23, 2024 | 09:02 AM
eddieo45's Avatar
@rapidoxidation 4 weeks; you getting close??
