13 ML350 POWER STEERING DEAD HELP!!!
Old Jan 23, 2024 | 11:10 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Got 13 ML350 from an auction, looks like it was hit in a front left wheel that rim got a big crack on the inside flat part that was touching a caliper a little.
Come to find out steering not working. i scanned it for codes got P063600, P06354, U041500,U042900. In addition to that i got P0300,
Looks like right side of alightment a little ii would say an inch toe out. no sign of any damage of speed sensor or wires.
I know its a electric steering now days. any idea what should i look for? help would be much appreciated. Thank you in advance.
Old Jan 25, 2024 | 11:57 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
I have never dealt with those P codes, but they seem related to the electric components of the steering ( https://www.obd-codes.com/p0636)
On the U code, they are CAN communication codes, in particular, related to the SCM (Steering control module).
I guess you already check ALL fuses, in particular,
Hope the above helps to start.
Old Jan 27, 2024 | 10:22 PM
IgorE350's Avatar
Yes, i noticed that these codes are together misfire and steering codes. I did check all the fuses front, dash and rear under the seat they all seem to be good.
but as usual in the boxes there is no booklets with fuse diagrams. sometimes at the action fuses get pulled out, so one might be missing or something.
i will check tomorrow the ones that u mentioned.
Sometimes next week i will inspect all the plugs on rack and if i can see any damage.
From little search i did on MB new steering, looks like people have lots of problems with them.
Thank you for your help,ill update when i look in to it more.
Old Jan 27, 2024 | 10:36 PM
JCM_MB's Avatar
https://fuseandrelay.com/mercedes/166-ml-gl.html
Old Jan 29, 2024 | 08:59 PM
IgorE350's Avatar
Thank you for the link thats really helpful!!!!
Checked fuse 11 is good and fuse 20 is good, no power steering.
Any other ideas what should i look for? any tests i can do? steering Column? or any sensors or any plugs at the rack? anyone have diagram where all wires go, where module is?
Old Jan 30, 2024 | 08:40 AM
vinceC's Avatar
2014 ML350 4Matic
The left front wheel is cracked, you estimate the right side is showing toe out by 1". Is there a possibility that the steering rack is internally damaged by what appears to be accident damage?
Old Jan 31, 2024 | 09:05 PM
IgorE350's Avatar
Yes, i am ready for that but still having hope that it can be some kind of sensor that is damaged or inner outer tierods damaged.
still didnt get a chance to get it in to the garage and inspect everything real good, been busy at work.
If i have to replace the whole rack, does it have to be programmed/adapted? or plug and play?
Old Feb 6, 2024 | 09:23 PM
IgorE350's Avatar
Today finally picked up a car, went under the car did some visual inspection. Do not see any external damage to the steering rack. Unplugged the wire harness checked for continuity positive, ground and the 2 wire plug from rack to the point where it attached on the box the positive lead where you jump the car. All good no problem there.
Found the reason why left wheel toe out about an inch out. Its the lower arm control shifted from the hit in the wheel. Will put it in place tomorrow, that should get wheels in place how they supposed to be. inner and outer tie-rods look ok to me no freeplay or anything bent or damaged.
Forgot to mention that my front bumper is off the car, insurance took it off to look for damage. and i noticed that it has a big sensor hiding inside of a smaller grill on the right side. Would that have anything to do with steering?
Old Feb 7, 2024 | 05:10 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
yes, the front lateral proximity interacts with steering and brakes -
EASY WAY FWD: Unplug the bumper side harness that connects to these radar modules.
Does that stop troubles?
Old Feb 28, 2024 | 09:40 PM
IgorE350's Avatar
Put bumper back on, got used steering rack hooked it up with wire harness looks like its working. Yesterday got diff off, ac compressor off to the side unscrewed the rack but couldn't get it out. gets stuck between the subframe. Anyone now the trick how to get it out? any special way i have to turn to get it out? It was late i left it for now, maybe tomorrow or Friday ill go try to get it out. any good tip would help. Thank you
Old Aug 7, 2024 | 05:45 PM
malik07's Avatar
13 Ml350 4matic
Put bumper back on, got used steering rack hooked it up with wire harness looks like its working. Yesterday got diff off, ac compressor off to the side unscrewed the rack but couldn't get it out. gets stuck between the subframe. Anyone now the trick how to get it out? any special way i have to turn to get it out? It was late i left it for now, maybe tomorrow or Friday I’ll go try to get it out. any good tip would help. Thank you
can you help I currently have the same problem did what you do work ?
Old Aug 8, 2024 | 11:14 PM
IgorE350's Avatar
HI, did you get it out?
Very important to pull up the engine a little . Unscrew the AC compressor and pull it to the side, without disconnecting the hoses. take front differential out and i took the right axle out completely and there is a part on the rack itself i had to brake a tab that sticking out and doest let the rack out.
and have to take the right shock out. When you done with the job replacing you have to adopt it to the car. because even if you clear the codes light will still come back. One good guy helped me with that for $100
sorry for late reply forgot to get on laptop yesterday. if any more questions feel free to ask.. God bless!!
