2013 ML350 - Ignition Switch not turning on
Old Nov 14, 2024 | 10:31 PM
Anna.K05's Avatar
2013 ML350 BLUTECH
Hi Everyone,
Looking for some help here. Roughly a month ago I started noticing that when I put the key in the ignition and turn it over the truck would not start. I would take the key out and put it back in and it would start.. It would still work on occasion when I push it in hard to the right. I have not been able to start truck at all now so I have taken out the EIS module (black Box) and now it seems to not want to go into the ON position to even use a OBD scanner/software to scan it. I fear I may have put it in a immobilization mode? (is that possible)
Is there a fix to the module that anyone maybe familiar with? I don't want to get a new module and have to program it.
Any advice greatly appreciated
Old Nov 15, 2024 | 03:10 AM
trigital's Avatar
W213 All-terrain
If you have the EIS taken out, you can carefully open the plastic cover from connectors side and look over the 3 pin PCB soldered connector for the coil.
Sometimes this connector needs to be re-soldered back on PCB side as when you lift up the PCB this can remain inside the plastic cover
Old Nov 15, 2024 | 08:46 AM
Anna.K05's Avatar
2013 ML350 BLUTECH
Seems like the 3 pins are connecting we used tin foil to test that. Is there any way to turn the electronics on so we can run the scanner or just to get it on the ON position?
Old Nov 15, 2024 | 09:17 AM
trigital's Avatar
W213 All-terrain
Pin's from connector needs to be soldered not "connecting".
Can you post a picture from 3 pin connector?
Depending on what scanner you've got, the EIS, CGW SAM',s, etc should communicate even if the contact circuit ( klema 15) is not on.
Old Nov 15, 2024 | 09:37 AM
Anna.K05's Avatar
2013 ML350 BLUTECH
Please take a look at the photos of the EIS
Old Nov 15, 2024 | 09:43 AM
trigital's Avatar
W213 All-terrain
Indeed, it's a new model.
Maybe the EIS has no any problem,
First step ( after checking the main battery, water in SAM or CGW...etc) is to connect a decent scanner for Actual Values regarding Drive Authorization, key recognition ( you can try another key as well ) on EIS - for this EIS only need to be connected into the car harness - also this harness should have voltage...
Old Nov 15, 2024 | 07:51 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
EIS MADE GOOD
welcome to simple electronics made reliable for pennies....
solder these 3 group of poor connections
take 5mn to solder these 3 groups of poor connections
the 3 empty open holes receive pins from the plastic assembly
> Next Stop:
-- Go visit solderless KeylessG module.... another 5mn fix responsible for "battery drain while parked".
-- CAN- B chaos will decrease as many module you solder.
-- Engine + tranny performance will increase when you deal with CAN-C
optocouplers that benefit being kept DUST-FREE !!
opto-coplers benefit being nearly DUST-FREE !!
