2014 ML350 Bluetec HVAC Lin 1 (U100887)
Old Dec 8, 2024 | 02:15 PM
n505906's Avatar
HVAC blowing hot air. No control of flaps. Only code is "U100887 D00887 - LIN bus 1 has a malfunction, the message is missing".
Wiring looks ok. Connections behind AAC controller all look good. Taken apart and reattached.
Anybody have an idea how to test to see if this is a stepper motor failure or shorted LIN cable?
Any assistance appreciated!
Old Dec 8, 2024 | 06:45 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W166 forum...
Old Jan 3, 2025 | 02:31 AM
lucasz's Avatar
I’m having same issue, any help would be appreciated
Old Jan 3, 2025 | 07:35 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
oxidized solderless pins...
99% chance your AAC module was built with nearly reliable pressed pins that got oxidized to become a poor connections.
-- Luckily this can quickly be soldered better than new with a basic AMZ soldering iron...
-- else you can troubleshoot the chassis until you know exactly where AAC LIN1 is connected then purchase new modules, get everything installed and coded...
Plan B: the flap actuators also feature the same solderless pins easily soldered as well.
See links in my signature where all this self-help is detailed.
Old Jan 16, 2025 | 07:01 PM
n505906's Avatar
Would you have a picture? Are you talking about the connection to the pc board inside the AAC module?
Old Jan 16, 2025 | 08:11 PM
Yes indeed.
If you have soldering skills, you can solder the marginal junctions under 10mn.
Follow this self-help link... AAC module is in there for ya.
