2013 ML350 intermittent not shifting out of Park
I did go to MB and purchase a Brake Sensor Switch. I removed the 3 screws and replaced this plastic Hall switch. The problem is persisting.
Hard to diagnose an intermittent problem. I've had this now 4 times... and eventually I can get the suv in gear after some brake pedal pushes and on/off.
Anyone have a direction to point me?
I will also add, i believe the vehicle has never had the original batteries changed. Not sure if this is a clue.
Much appreciated.
Much appreciated.
Simply use an Mb scanner to read the gear selection from SCM and ISM Modules the you'll know what's wrong.
Is this scanner something a novice can use and figure our? Or is this a trip to a service center for them to read the codes and diagnosis?
Much appreciated.
Any more thoughts on what could be causing the ML350 to intermittently not shift out of park?
In post #2 I hinted using a scanner: let your local specialist take care of this repair.
1. replace AUX battery
2. replace main battery
3. reset ECU
After you are finished reinstalling the new battery you now need to reset the ECU or your ML350 will not switch gears out of park.
- If you have Keyless Go, pop off the Keyless Go button
- Insert the key
- Turn the key to "ON" - not start - and leave it "ON" for more than 2 minutes
- Turn the key to "OFF", but leave the key "IN" for at least 10 seconds
- After at least 10 seconds, turn the key to "ON", push and hold the brake, turn the key to "START" and the car should start. Verify that you can switch gears.
- If you have Keyless Go replace the Keyless Go button
Same for both FOBs. FOB and auxilliary batteries both recently replaced.
I can guess the button activates internal antenna to constantly verify button presence and it drives battery current down causing shift failure. MB is super sensitive to right voltage
So you say mb are sensitive to battery voltage. I can believe that plus or minus. And your saying the antenna upon pressing the button drives enough current to lower the battery voltage ?
Really ? If that’s the case I should be able to
see that by measuring the battery voltage during those events Or… attach the battery to a charger so the voltage wouldn’t drop. I’m not ***** Nilly swapping out fairly expensive batteries just on a hunch. Is there not any other way of determining root cause vs adhoc replacement?
just a p.s. a 2013 ML350 has two batteries ? Not sure what you’re referring to regarding replacing both batteries.
didnt have one but checked physically today and confirmed. Have ordered an oem aux battery. Thanks for the heads up.
Ran Obd scanner and returned no faults.
Another weird thing I discovered .. car will start and shift normally using keyless go if the passenger door is left ajar (but not driver's door)?
just an update. Replaced the aux battery. The battery access / replacement procedure that I used on YouTube is totally incorrect. It was one nut removed and the cage holding the battery coms off. Mine were slip on connectors only. And glad
to report my stater button / shift issue appears
to be resolved. As I used it for age days I will confirm but all good for now. Thanks all. ! Never would I have believed here was an aux battery
