Advice on purchasing 15 ML 350 4matic
I can get it for 11k.
Anything to look for in particular? It doesn't have the air suspension which is good.
No CEL, or warnings. Plugs and rear diff were changed at 75k. Has Premium 1 and lighting pkg.
Can you go into more detail for the service history?
Transmission fluid service?
Rear/front diffs and transfer case fluids serviced?
Last time spark plugs were changed?
Were front timing covers resealed?
And most importantly, what was the oil change interval? Every 10k or 7.5k or 5k miles and what oil was used and where was it done?
If you can negotiate down on price, it does seem a *little* high considering the mileage.
I think I'll wait for a lower mileage one with a more detailed service history.
They battery locations are are ridiculous. And considering all the electrical issues I've had on my w211, I may reconsider all together. Im reading some horror stories about the keyless go issues on YouTube too. I'll keep searching I guess and hope to find a gem!
What are the most common issues besides the push start thing?
- transmission oil change --> if it hasn't been done, negotiate the price lower. This is ~$750 at the dealer.
- oil leaks at the front of the cylinder heads --> same as above. This is $750-$1000 at the dealer.
- oil in the cam position sensor connector and cam magnet connector. Tough call. If in the early stage, the leaking can be mitigated by cleaning, sacrificial pigtails and replacing sensors and magnets. In advanced stages the ECU can become contaminated with oil.
If you drive through dark areas, the Halogen lighting is poor. The Bixenon package is waiting for.
