Replacement Radiator
I purchased a replacement- Nissens. It has ports for the integrated transmission cooler, however when I took the fan out, I saw the existing radiator DOES NOT have the integrated transmission cooler. It appears the transmission cooler is external to the radiator.
I am having trouble finding a replacement without the integrated cooler- Do I simply install the new radiator with the ports, or is there a replacement that does not have the cooler?
Part number on the original radiator is A099 500 00 04.
Thank you!
Last edited by Chris 2012ML350; Dec 6, 2025 at 09:51 AM. Reason: additional context
The "If" part is the challenge......
I don't want to take the whole thing apart and the old one out only to find that the new one doesn't fit...... then I am stuck with a mess- either putting the old one back or waiting until I can find the correct part.
If the part I got is the current standard replacement, then what would I plug the TOC ports with?
Model is 166 057
I am at a loss....
New
Old
No connections
Connections
New
Old
No connections
Connections
What dud you do with the ports? Plug them? (with what?) Or just leave them bare?
I ask, because I overhauled the entire cooling system (replaced all engine and transmission cooling components: water pump, thermostat, radiator, expansion tank reservoir, hoses, coolant lines, transmission lines, clamps, bolts, seals, etc.) on our old 2004 E 500 S211 wagon a year ago and used Genuine Mercedes parts for everything on that car other than the radiator, which was a Mahle-Behr "OEM" unit I had purchased from FCP Euro. Well, I now have a new, very small coolant leak at where the upper radiator hose fits into the radiator after this prolonged polar vortex we've experienced in northern New England. I just got the "check coolant level" warning for the first time yesterday and had to add a little less than a quart of coolant to the expansion tank reservoir. When the temps get into the high 20°s Fahrenheit (rare, as of late...) or when the car is driven, the leak stops (or if the car just sits out in the extreme cold without running). The leak only occurs overnight after driving the car and then letting it sit in the extreme cold afterwards. I suspect that I need thicker/better O-ring seals for the hoses (radiator was pressure-tested last year when I got it, and the entire system was pressure-tested at the AlphaCars service shop when the installation was completed)... Up until sometime during the December polar vortex up here, the radiator and cooling system had been flawless and performing well (including earlier in the summer, when I was still in the U.S.)...
