M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
V12TT Coil Pack DIY Replacement - With Pictures
Old 01-27-2017, 11:37 AM
Dr Matt's Avatar
05 CL65
Yes, E type sockets.
Old 02-03-2017, 07:07 PM
amstel78's Avatar
2006 W220 S65 AMG
I did it once without that special tool.. And the rest with that ingenious tool.
Its easier with the tool. Made by Hazet, Mercedes Part# 137589003300.
You need the base too 285589009400 which is used to leverage on the valve cylinder cover, and pivots the coil out a bit at a time..
Again not necessary, just makes it easier.
Where can this tool be purchased from? A google search of the part numbers provided yields nothing related to it.
Old 08-19-2018, 12:55 AM
Tusc's Avatar
S600 - 2003
A huge thanks once again for this thread. What an easy car to work on - especially with the guide. I am just wrapping up doing both coils on my car and kept the post open on my garage phone as a quick guide. The first one goes slowish, but the second side was a breeze.
If anyone buys exchange coils from V12icpack, know that they do come with new boots so don't go and buy a set like I did.
As for a special tool.... I did not need one. I have hands that break steel, but I kept them throttled down. The key is to be Slow, and Steady. Think Torque, not Horsepower. In my case I alternated between ends and then the middle to gently press them out.
The car is a happy beast again!
Old 07-05-2020, 03:23 PM
Investmentguru's Avatar
04 SL600
Hi,
In regards to step 4, there is a wire that runs underneath the coil pack. (It's noted in the caption to "be mindful of these wires when removing the coil pack')
It looks as if one end of the wire is connected to the harness, but where does the other side of the wire connect to? On my car, one side of the wire is connected to the harness, however the other side is completely disconnected. (Which isn't entirely surprising since my coil packs were recently replaced.)
Thanks in advance!
-Brandon
Quick Reply: V12TT Coil Pack DIY Replacement - With Pictures
