M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Data Logging Boost Pressure and Others results.
Old Nov 21, 2011 | 05:04 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Originally Posted by Dynodaddy
I have precision turbo billet compressor wheels in my S600 and it will hold 20psi until the rev limiter. The issue with these cars is not the turbo's it is the tiny exhaust manifolds that are creating an insane amount of backpressure.
I started from scratch and just finished the first tuning session with Jerry @ Eurocharged this weekend @ Autoscope in Dallas. I have a bad coilpack and we didn't get too far with the tuning but @ 17psi the car made 808rwhp and 1327ftlbs of torque on 93 octane only pulling to 4600rpm's. I will push the car as far as the injectors will allow during the next dyno session, and I have a feeling we will not need race fuel to max the injectors out. I believe I will make 900+ rwhp and almost 1500ft lbs of torque if the dyno can hold the power.
This car has the power to easily accomplish my goal of running 9 second 1/4 mile times and with any luck will perhaps break the 9.5 second barrier.
can't wait to see her run!
Awesome job!
Old Nov 23, 2011 | 07:14 PM
RaceHorse's Avatar
CL65
Very cool to see what you have done, it obvious you have alot of thought and sweat invested, great way to think outside the box, impliment you own ideas and take it to a whole new level. What's your plan for the drivetrain specifically rear and axles? You may want to check with Peterbuilt to see what your options are. (hahaha) Have you installed the new coil packs yet? Let us know what its like to drive, videos for those with little imagination, Hey lots of luck as the race for 9's continues!!!
Old Nov 24, 2011 | 06:26 AM
AMG-Driver's Avatar
SL65 R230
Good luck with your built. But if would you use all of this Power often e.g. on our German Autobahn, the car won't drive long without running into problems with Engine and Transmission...
I have quite a good contact to one if not the best MB-Tuner in Germany, who tuned my SL600... He has "inside-information" of MB-and AMG Engine-Development, and he knows the limits for M275 Engine and Transmission very well.
Old Nov 24, 2011 | 08:57 AM
Dynodaddy's Avatar
03 S600 11.7 @120, CL600
You are absolutely correct. Road racing and drag racing are two completely different animals. As it stands I doubt the tranny will last more than a few passes at the track. I am already ordering the parts to upgrade the tranny and install two additional clutches in 1-2, & 2-3. And a few other things.
If I have too many issues with the rearend and halfahafts I will install a 9" rearend.
Old Nov 26, 2011 | 05:41 AM
Vabene7's Avatar
Garage Temporarily Empty
To make that kind of power, was the major mod the billet turbos?
I am just curious what leapfrogged you from about 600hp with a tuned S600 to 808HP & 1300FT-LBS of torque.
Have you removed your primary cats?
Thanks...
Amazing gains....I am excited to see a video of your car in the 1/4.
Old Nov 26, 2011 | 09:06 AM
Dynodaddy's Avatar
The majority of the increase in power is the manifold size and design. The larger, far more effiecent turbo's helped a lot too. I do not have cats on this car or my S600.
Thanks...
Old Nov 26, 2011 | 10:39 AM
  #32
1995E320Cab's Avatar
2003 CL600 2005 745Li
Dynodaddy what are you doing to keep you V12TT running cool as it loves ?
- What Heat Exchanger set up, did you keep the stock unit and add to it or ?
- What Heat Exchanger pump ?
- Are you running a extra tank, if so what size and where ?
- Who made your intercoolers ?
- Anything else you have done to keep it cool ?
Old Nov 26, 2011 | 03:45 PM
  #33
Dynodaddy's Avatar
I have a 5 gallon fuel cell in the trunk with a 120LPH electric engine water pump sending water through 1" lines all the way to the heat exchanger in the front of the car. I am running roughly a small radiator for the heat exchanger 14" X 24" X 1.25" thick (-16an in and out) to a -16an X (2) -12an "Y". This splits one -12an to each intercooler, through the intercooler, then "Y" back into a -16an hose back to the reservoir in the truck.
After talking to Bell intercooler about my power needs they reccomended these cores along with a certain GPM flow rate to keep them operating at optimum efficency. I then took the raw cores and welded the tanks and endcaps on the unit. On air to water units you have to be careful on your water inlet and outlet to make sure that you do not have a place for air pockets to form or you will have a hot spot in the intercooler.
