M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
The all new M279 6.0L V12 biturbo *pictures*
Old Apr 6, 2012 | 03:42 PM
Oxygen's Avatar
W220 S65 AMG
Arrow The all new M279 6.0L V12 biturbo *pictures*
I hope you didn't hold your breath for this one. Nothing new on the surface except for a matte carbon fiber cover instead of a glossy one...
From what I could see, airboxes, throttle body and intercoolers looked the same as the M275.
Old Apr 6, 2012 | 08:30 PM
RaceHorse's Avatar
CL65
So whats the deal, same displacement but a new motor design and designation M279 as opposed to the M275? The Hp is up a few but torque the same just matched with a 7 speed tranny? Is that at the Jacobs Javits Center already, you don't mess around. I wonder if a tranny swap is the next step in a modded 65.
Old Apr 6, 2012 | 08:36 PM
Oxygen's Avatar
W220 S65 AMG
Yes this is the at the Javits center last night, the gentlemen in the black blazer on stage is AMG's CEO
Well, I am surprised they called it an M279 when it's actually an M275 with some upgraded parts. The only thing that's changed externally is a matte carbon cover and a yellow plug where the dipstick would go.
Here's more about the new M279...
The AMG 6-litre V12 biturbo engine with the designation M 279 is based on the M 275 engine used previously and has been comprehensively revised for the new SL 65 AMG. New exhaust gas turbochargers with an increased spiral cross-section, new manifolds and wastegate ducts with optimised flow characteristics increase the engine output by 13 kW (18 hp). The multi-spark ignition with twelve double ignition coils not only results in smoother running, but also enables even more effective combustion in combination with a new engine management system with higher performance and optimised cylinder heads. The resulting reduction in exhaust emissions is also due to a large extent to the optimised catalytic converter system. The newly developed AMG sports exhaust system, which has a pipe layout with enhanced flow characteristics, is 3.2 kilograms lighter as a result of a reduction in the wall thickness.
But it is not just the inner qualities of the AMG 6-litre V12 biturbo engine that impress. The powerplant's looks are as inspiring as its performance: the high-quality carbon-fibre and aluminium engine cover reflects the exceptional character of the powerful twelve-cylinder unit.
For the first time AMG has combined the 6-litre V12 biturbo engine with the AMG SPEEDSHIFT PLUS 7G-TRONIC. The seven-speed automatic transmission with its wide gear ratio spread enables a significantly lower engine speed and helps to reduce fuel consumption. A new fuel economy torque converter, bearings designed for reduced friction loss and the transmission-oil thermal management system are responsible for a further increase in the efficiency of the power transmission system.
The AMG SPEEDSHIFT PLUS 7G-TRONIC has four different driving modes - Controlled Efficiency (C), Sport (S), Sport plus (S+) and Manual (M) - which can be selected at the push of a button on the centre console. In "C" mode the ECO start/stop function is permanently active. The compelling, dynamic character of the driving experience is made all the more vivid by the automatic double-declutching function during downshifts and through the brief, precisely defined interruption of ignition and fuel injection during upshifts under full load; the latter functionality has the additional benefit of reducing the shift times.
Old Apr 7, 2012 | 04:27 PM
Oxygen's Avatar
W220 S65 AMG
V12 Biturbo Produktion...
Old Apr 8, 2012 | 06:08 AM
the head's Avatar
18 Titan XD 13 Cayenne TT 13 BMW HP4
Not really a mechanical component change but at least the air intakes up front are moved to a potentially better spot.
Old May 6, 2012 | 03:06 AM
freestylebiker3's Avatar
w215 cl65, W212 E63, R53 Mini Cooper JCW, E92 328I
seems like it has a spot to check your engine oil manually unlike the 275 engine
Old May 6, 2012 | 03:09 AM
oxygen, thanks for your those pictures.. i love those close up pics of the 275 engine you posted last year,, keep them coming
Old May 6, 2012 | 03:26 PM
grane's Avatar
GLK350, SL63 AMG
I asked one the the two people onstage if they had fixed the notorious V12 coil pack problem and I was told "not yet."
Thus the press release account of the system is problematic and leaves questions since I am not a V12 maven. Does anyone else have a clearer idea or information?
Old May 10, 2012 | 01:24 PM
MRAMG1's Avatar
S600, GL450, GLC 43
VERY disapointing that they would keep our crappy intercoolers
But as usual Cris, THANKS for the photos
Old Jul 12, 2013 | 07:11 AM
Welwynnick's Avatar
2006 S600
Just noticed that the alternator appears to be air-cooled instead of water-cooled.
Nick
