M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
2005 Mercedes CL600 Gearing Questions
Old Oct 15, 2012 | 12:03 AM
KazukiZhou's Avatar
CL600
When I do dig runs or pulls, the car goes from 1st gear to 3rd gear and completely skips 2ed Gear.
Is that normal? every time I launch it happens.
Old Oct 15, 2012 | 08:14 AM
Welwynnick's Avatar
2006 S600
Sounds unlikely.
You sure you're not just starting off in second?
Which mode do you set your transmission - S or C?
Do you leave it in auto, or select the gears "manually"?
Do you use kickdown?
Nick
Old Oct 15, 2012 | 01:19 PM
KazukiZhou's Avatar
CL600
I'm positive I'm starting off in 1st gear or at least mostly sure. I use S and the gear select mode into 1st. When I launch the car it would not change gears until 5700 RPM and then the gear selector would say 3rd gear.
