M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
How many MAP sensors?
Old Mar 11, 2013 | 10:59 PM
saintz's Avatar
GL450
Are there 4 MAP sensors on the V12TT?
I see one on each air box and one T'd off the passenger IC (mounted above the TB). That's 3 total.
Is there a 4th underneath the ICM that meters post-TB?
Old Mar 12, 2013 | 03:55 AM
Welwynnick's Avatar
2006 S600
You're right about the locations, but I can't remember if they're ALL MAP sensors. The ones on the IC's might be temp sensors. The important one is on the intake manifold itself, downstream of the throttle, under the ignition amp. You can almost certainly find the right answer from the link in this thread:
https://mbworld.org/forums/m275-v12-...75-freaks.html
Old Mar 13, 2013 | 11:16 AM
saintz's Avatar
GL450
Great link, thanks!
Old Jun 14, 2016 | 02:48 PM
ZephTheChef's Avatar
2004 S600
Old thread, I know. But for future searchers I feel like I should update this. There are actually at least 5 air pressure sensors, but only 4 can be independently replaced. One in the intake manifold, one referenced to the passenger intercooler outlet (pre-throttle body), one in each airbox, and #5 is internal to the engine computer as an atmospheric reference. There could be more that I haven't stumbled across yet.
Old Jun 14, 2016 | 07:48 PM
Dr Matt's Avatar
05 CL65
After dealing with a boost issue 2-1/2 years ago I found the same results you did. The two in the air boxes only measure vacuum and are different than the one in the manifold and the one attached to the intercooler by a hose. The air box sensors are not interchangeable with the other two.
Old Jun 14, 2016 | 08:12 PM
2004 S600
Agreed. And if you go to the parts store and order a map sensor, you'll get one of those. If it's $50, BE SUSPECT. It's probably not the right sensor. The two pressure ones are a couple hundred bucks. They will physically interchange and plug right in but you'll have issues.
Also, be careful not to switch the plugs on the passenger side airbox and intercooler outlet map. They will reach and it will run and drive fine at low load, but it will cause very unpleasant results when you give it more than about half throttle.
