Misfires at moderate accelaration
Symptoms: multiple misfires when accelerating moderately, pedal at about ¼ to 1/3 of WOT. Happens all the time no exceptions. As soon as I try to give a bit of gas I get misfires. If I accelerate real easy its fine, I can drive at highway speeds for hours without any trouble as long as I don’t give it much gas, once again if at highways speeds I moderately accelerate I will get misfires. After misfires engine runs very badly, severe vibration until restart then it runs smoothly as long as I don’t accelerate…
It seems to misfire exactly when turbos kick in, after a couple of tests this morning, car was cold, as soon as i hear the turbos spool hesitation and misfires start.
Stored codes are P0300, P0302, P0304, P0307, P0309, P0308, P0310, P0306, P0303, P0305 pretty much all cylinders misfire, both sides.
Further more lately car did not start-up well after shut down at operational temp, this is symptoms of a bad the crank position sensor, I don’t know if it could affect my new misfire problem.
CEL does not go away, even after multiple startups
I don’t think it’s the gas, problem started at ¼ tank, refueled since, problem persists
Usual suspects would be coil packs, sparks, ignition voltage controller, gas pump/filter?, EGR?, cats.
car has 100000km
I think we can rule out some suspects due to the misfires being in both banks, like the cats and maybe coil packs?
Any suggestions appreciated, I will get the car serviced at my local dealer as usual, but I would like to guide them a bit in the diagnosis…
car has 100000km
i think ignition voltage module.
Thanks for the replies, I would of thought that if it was the ignition voltage controller that I would get misfires at startup as well, not only upon acceleration.
The car will be at the dealer next week, I will post the outcome of the repairs, hopefully they will pinpoint the problem immediately and not change a multitude of unnecessary parts before getting it right.
From experience, it is recommended that you change both coils AND the voltage transformer at the same time. The problem is always at higher rpms when the coil system is put to its limits. If one is slightly weak, it will misfire the whole system. All three units must be at 100%. Life is usually at 30-40K miles. It is the poorest engineering design in this whole engine and they haven't fixed it to date. It is the cost factored in having this monster engine. Been there, done that.
My misfires start at 2000 rpm if I press the accelerator at about 1/3, at neutral I can rev at at least 4000rpm without misfires, the problem is only at load/power demand
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Dropped the car at the dealer today, they called back saying that my fuel pressure is way low at 2 bars, they will replace the filter and see if that fixes the problem.
What is the correct fuel pressure anyway?
I believe the V12TT's use variable output fuel pumps, which is unusual. Maybe the controller is at fault? The symptoms do sound fuel starvation / blocked fuel filter though.
After installing new filter still very low pressure, They have ordered a fuel pump assembly. None available in Canada so it might take up to 1 week.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Got the car back today, they replaced the fuel pump control unit
part# 220 540 29 45
Car runs great once again!
part# 220 540 29 45
HopefullyE63 (05-18-2019)
Yes, maybe worst in the sense that I had to be very very gentle on the throttle, what I don't understand is that the original fix work for a couple of days.
Anyways I got the car back, it is working perfectly once more. They replaced the fuel pressure sensor part #463 905 34 00, the relay and wiring for the part.
Voila!
Voila!
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
1 Post
W220_S600 V12 BiTurbo
Excellent, I congratulate you and I hope does not come back again.
I had a similar issue for my car (W221 S600), and after many of the diagnosis for a long time more than five months, the problem was from secondary air injection (P0410 fault code).
Voila!![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Voila!
An eBay listing gives some details about the harness needed
"This Listing Contains: 1 X 4639053400 -Genuine Mercedes-Benz Fuel Pressure Sensor -Inline Also Use: (Qty.) 1 X 4635409213 -Wiring Harness (NOT included). New - Genuine Mercedes-Benz 463 905 34 00 / 463-905-34-00 / 4639053400 Fuel Pressure Sensor-Inline."
