Intercooler Circuit Overflow Reservoir
With the bleed valves you installed, do you know the size of the ones you installed?
Do you leave them open internally all the time? If so, I assume the bleed valves are there to limit flow purely for continuous bleeding purposes?
The bleed hoses do by-pass the intercoolers, but the holes are about one percent of the cross section area of the main pipes, so its a tiny loss of flow. There are other mitigators.
Those ports on top of the IC's really should be bleeders, not fillers, as they're on the top, not the bottom.
Nick
Regards
Regards
It is very easy to install....
https://mbworld.org/forums/m275-v12-...atibility.html
The root cause of the problems I had, by the way, was a bad coolant pump in the IC circuit. It had been bad for quite a while, apparently, because when i bought the car the IC system was half empty.
I can think of better designs, but Mercedes didn't ask me before they built it.
Where the overflow tank helps is if the system gets hot enough to vent a little coolant, then it will suck coolant back in instead of air when it cools down. As designed I think the engineers thought that should never happen under normal circumstances, with a perfectly operating pressure cap and the expected range of temperature. Well, circumstances are not always normal, caps and seals are not always perfect, and sometimes things get a little hotter than they expected, I guess.
I do not agree, I have been testing a lot and even build 2 vacuum machines
like Welwynnick said:
The header tank has lots of advantages, and it HELPS to keep air out, but you still need to bleed the system.
a good bleeding with a vacuum takes 45-60 minutes
then once done, and with this new tank, you'll never have air again, I never had
(not the case at all with old system)
then after that it will autoremove the little left and prevent having air
edit corrected see below
