M279 Improvements Backward Compatibility
Is there a threaded cap that fits this and the MB coolant reservoir?
As for the threaded-cap question, I don't know if there's one that fits the MB coolant reservoir, but there is one that fits the original M275 parts. Open the stock cap, put this on, apply some coolant with a little air pressure, and let the air bleed out.
it's not going to do that automatically
but the new tank will prevent air to get into the system
https://mbworld.org/forums/cl-class-...l-version.html
I have not tried any other parts but had the idea of trying a transmission fill tube from a 2013 or newer SL. However, I have not been able to find a picture of where the fill tube is routed on the newer models. If anyone has a picture that shows this it would be helpful. The big downside of replacing the transmission fill tube is I believe the transmission would have to be dropped to do this. The latest idea I had was heating the new coolant tank with a heat gun in this area and trying to remold it just enough for clearance. I am open to suggestions. Is anyone else trying to do this in an SL?
What I would do is following, cut the pipe on the place where it should bend away, find a nice piece hose that fits perfect, put it around both cut parts to join them back together
you can pull the pipe out of the trans easy once 50 and 60 removed
I ordered new hoses (which is probably a good idea after 14 years) but they will take a couple of weeks to get here. Oddly, one of the new hoses on the conversion was also leaking during the pressure test as well. The Mercedes "specialist" on the phone from where I ordered the parts thought it could be the metal spring clips had lost some of their clamping force over the years and would not clamp the hoses enough after unseating them during the conversion. I am skeptical but ordered new metal spring clips as well. I hate to use worm drive hose clamps on the system but may consider that if nothing else works.
Spacer
Spacer
so you succeed copy the bleeder like I did
What was the diameter of the hose you used for the splice?
I think the hose size I used was 7/16 inch. It was a tight fit so I heated the hose up with a heat gun to get it on the tubing.
If I had to do it over again I would probably try to cut it higher up, possibly after the last bend in the tubing, if I thought there would still be enough room for the bend.
Finally, if I was to do it over again, I might try to heat the tube up with a torch enough to bend it and do away with the rubber hose entirely.
On my car the head of the bolt faces the firewall instead of the engine bay and it looks like it might be a pain to get access, even once I have the old intercooler cap and hoses removed.
It will also be a reach to remove the middle bolt attaching the tube to the transmission but it is doable.
The final bolt to remove the tube is a standard 10mm bolt. It will need to be removed from underneath the car just above where the tube fits into the transmission. The way I reached it was using an extra long wrench such as a 10mm x 120mm (or more) flex head ratcheting wrench on one side and standard wrench on the other side.
Thanks,
Eric
The bracket that’s about half way down the tube is not connected on my car, I’m not sure if that makes any difference. At some point a mechanic must have been working on the car and never reattached it and I’ve left it that way.
You absolutely need to vacuum bleed the system when you are finished. Good luck with the job!
also, these pliers make the job soooooo much easier
