M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
M279 Improvements Backward Compatibility
Rating: Thread Rating: 2 votes, 5.00 average.
Old May 2, 2021 | 08:50 PM
  #51
drlc01's Avatar
2005 SL65 AMG, 1987 560SL
Originally Posted by sivikvtec
Still no issues. I even used the tube a few months ago when I changed the trans fluid and it worked fine and the dipstick went in it without any problems.
The bracket that’s about half way down the tube is not connected on my car, I’m not sure if that makes any difference. At some point a mechanic must have been working on the car and never reattached it and I’ve left it that way.
You absolutely need to vacuum bleed the system when you are finished. Good luck with the job!
also, these pliers make the job soooooo much easier
https://www.amazon.com/gp/aw/d/B07RTQV4F1?psc=1&ref=ppx_pop_mob_b_asin_title https://www.amazon.com/gp/aw/d/B07RTQV4F1?psc=1&ref=ppx_pop_mob_b_asin_title
Sivikvtec, thank you so much for your quick reply. I will try to loosen that middle bolt as well, maybe add some spacers to it and reconnect. I'm wondering if the M279 filler tube works better, maybe something for a later retrofit.
Thanks for the pliers advice.
Eric
Old May 20, 2021 | 12:45 PM
  #52
drlc01's Avatar
Still didn't get the time to make the changes. What are you guys using for a cooling fluid mixture is it 50/50, I have read on some forums, not specific Mercedes, that some people use a higher percentage water, reasons mentioned are that the pump can do a better job circulating a lighter mixture.
What are your experiences? does anybody know what the Mercedes recommended mixture is? (I'm in Texas)
Also I saw a video on youtube (
) with a intercooler fill on a Maybach, a little bit more modern vacuum pump and improved procedure but basically the same process, so just another confirmation regarding your bleeding systems.
Eric
Old May 20, 2021 | 12:55 PM
  #53
drlc01's Avatar
Sorry, this is engine coolant fill, not intercooler fill, but same setup with vacuum pump.....
Old May 21, 2021 | 03:34 PM
  #54
DaleB's Avatar
Veteran: Army
2007 S600
I'm running 50/50, or close to it. I need winter protection down to at least -20, preferably lower. I don't think any different mix is going to make a measurable difference in effectiveness. If you live where you never see freezing temperatures, you could run straight water with a wetting agent... but then you're giving up the corrosion protection of the coolant for the advertised (not tested or proven in your car) corrosion protection of the wetting agent.
People often get wrapped up in theoretical marginal improvements. The pump should be more effective with a lighter mixture? Maybe. But would it be more effective by any measurable amount, let alone enough to be of any practical value? I'd love to see some actual flow testing. And in the case of our intercoolers, there would have to be a BIG difference in cooling to make any detectable difference in the performance of the car.
So, the short answer -- Mercedes says to run 50/50, I run 50/50.
Old May 21, 2021 | 10:15 PM
  #55
drlc01's Avatar
DaleB, thanks for your response.
Old May 22, 2021 | 12:04 PM
  #56
JJKCMO's Avatar
Exige S | V70R | CTS-V wagon | JKUR | 13 S65 (Mocha/Armagnac)
But how would aftermarket manufacturers sell product if they actually had to provide hard data on measurable rather than theoretical benefits?
Old May 22, 2021 | 03:23 PM
  #57
DaleB's Avatar
Veteran: Army
2007 S600
Hahaha... it would certainly be a thin market, wouldn't it? I keep wondering if I should buy one of those little OBD widgets they sell all over eBay for $29 that guarantee massive HP/TQ gains AND better mileage just by plugging it in...
150 Horsepower Gain is Very Easily Felt.
145 lb-ft Torque Increase Greatly Boosts
Hill Climbing and Acceleration From Low Speeds
6 Miles Per Gallon Boost Saves Gas and Fuel Costs.
Old Aug 18, 2025 | 03:42 PM
  #58
DavidLN's Avatar
CL600, ML550, SL65
Greetings:
I hope I'm not too late to get a little help with this project. I'm doing the R12 to R134 adapter change to facilitate bleeding. I'm a bit confused as to which schrader valves need to be removed. My adapters will not go on unless I remove the valve in the intercooler pipe. I bought the R134 valves but no matter wheter they are open or closed I cannot blow any air through them. I must not understand some details here. Some help would be great.
Dave
Old Aug 18, 2025 | 04:17 PM
  #59
sivikvtec's Avatar
2005 SL65 AMG
The adapter kit I bought on Amazon is no longer available, but this one appears to be the same. You need two kits since only one adapter in the kit works.
Amazon Amazon
Old Aug 18, 2025 | 04:59 PM
  #60
DavidLN's Avatar
CL600, ML550, SL65
Thank you so much for the quick response. I just ordered two kits. They will be here tomorrow.
Sincerely.
Dave
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
