M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
S65 AMG misfire
Old May 25, 2017 | 11:42 AM
  #76
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
Originally Posted by biker349
the question is which wires from the coil pack is he attaching to a battery source and what type of battery source. he shows you everything but the wiring which is the most important part.
Sure its his business, so not surprising that he is keeping the info close to his chest.
Getting them to fire should be easy, figuring out the communication between the coil packs and the ecu is the harder bit.
Old May 25, 2017 | 04:30 PM
  #77
biker349's Avatar
cl600
if it's easy to get the coil packs to fire i would be very interested in how to do it.
Old May 25, 2017 | 04:42 PM
  #78
If I end up replacing them on mine. I'll try and get the old ones reverse engineered.
Old May 26, 2017 | 04:56 PM
  #79
biker349's Avatar
cl600
looking forward to it.
Old May 29, 2017 | 05:00 PM
  #80
Some progress.
Meth system install finished today. The good news is that the car does not misfire, even with full flow on the 14GPH nozzle at full load. Intake temps plummet with it on, lovely.
The bad news it that I still only have 15 psi. I will be doing some testing on the dyno tomorrow, and will see if the car is still logging engine knock. I am running about 65% methanol with 99 RON (uk) fuel) so if it is, I will be 90% sure that its false....
Old May 29, 2017 | 06:34 PM
  #81
ZephTheChef's Avatar
2004 S600
water/meth is magical. If you have knock reported still, I'd be conaidering changing those sensors and wrapping the new ones with dynamat or similar car audio vibration dampener. we've had good luck with that eliminating false knock retard without affecting the sensor's ability to pick up real knock on 3800 engines.
Old May 29, 2017 | 06:39 PM
  #82
It is a bit odd. Its quite involved changing all the sensors, but it must be false knock if if 99Ron and 50/50 Meth injection at 14GPH! Is it possible that they all fail at once?
Old May 29, 2017 | 06:44 PM
  #83
2004 S600
false knock on the 3800s is usually a result of worn motor mounts or something out of place that's banging on something and causing a vibration/ring through the engine much like knock/detonation would. I don't know what the failure behabior for the sensors is, but I know in the GM trucks at least they are a very high failure rate. Those trucks set a code for it and the symptom is reduced power but I habe never looked at the sensor signal on a bad one to see how they actually behave when failing.
Old May 29, 2017 | 06:49 PM
  #84
I thought that too, so when I was underneath it I checked all items around the engine for loose/rattles.
All exhaust clamps are tight and done up. I do have a slight rattle from the passenger side header where the clamps are just before the turbo, but I have to hit it with a pry bar directly to hear it. If I hit the exhaust with a rubber mallet all over, it does not rattle or have anything loose.
All mounts on the car are new and nothing is loose on the underside of the engine.
Will see whats happening on it tomorrow. I would think that one sensor would pickup false knock rather than all 4 if it where a loose object. Its possible that they have all failed, like you say.
Old May 30, 2017 | 03:27 PM
  #85
2004 S600
I don't think they would all have to fail for you to have issues. I suspect the purpose of having 4 is for enhanced sensitivity, to be able to detect knock regardless of where it occurs in the engine. The computer may well not care where the knock signal comes from...if it detects knock it's most likely going to respond across the board as opposed to by quadrant. So if you've even got one that's acting up it could be pulling boost/timing.
Old May 31, 2017 | 12:07 PM
  #86
OK so back from the tuner today.
He also did knock testing whilst on the dyno and can not see any appreciable knock detection occurring so that was a red herring.
He says my car has an odd software version and its not like any of the other 275's he has tuned in R230s/215's/220s. As a result he thinks that maybe the section he is tweaking may not be correct for my car. He is going to continue to compare maps and investigate.
On the dyno we did pull the hose that goes to water injection system (to bleed wastegate boost) and the car picked up 100hp and 130 ftl-lbs. We had no way to monitor boost on that run (due to the disconnected pipe) but it would still point to a control issue.
Old May 31, 2017 | 12:12 PM
  #87
2004 S600
I'm at a loss as to why the computer would limit boost other than: high intake temps, or that it detected knock. Perhaps the transmission computer is telling it to reduce torque?
Old May 31, 2017 | 12:20 PM
  #88
I am too. I had the same thoughts regarding the gearbox limiting torque, but cant explain why it would do that.
After testing on the dyno, he said its possible the turbo's are worn and just cant make the boost.
I told him that clamping the wastegate line from the back of the IC puts the car into immediate limp from over boost which means its unlikely the turbo's were worn.
That is when he pulled the line from the T that I had installed and ran it again (and it made the gains).
I was expecting it to overboost, but the T I installed must have a small enough restriction in it that it didn't overboost but built more boost than normal.
I clamped the line again when home and it gave overboost and the same misfires it did early on in this thread, when I wound in the wastegates (both banks).
I will be replacing the plugs soon and by then my tuner should have some info.
Old May 31, 2017 | 02:28 PM
  #89
Welwynnick's Avatar
2006 S600
Interesting progress, but be careful with the plugs. Make sure you fit plugs with 0.7mm gap and not 1.0mm. Several dependable sources get that wrong. If in doubt fit NGK IFR6Q-G.
Nick
Old May 31, 2017 | 04:04 PM
  #90
Nick
Thanks Nick, I have a box of IFR6Q-G sitting here, so I am glad you said that!
Just waiting on the new rubber insulators.
Old May 31, 2017 | 04:45 PM
  #91
Welwynnick's Avatar
2006 S600
Countless coil packs have been fried by Bosch FR7KPP33U+
Nick
Old May 31, 2017 | 04:53 PM
  #92
Although I have a feeling my packs are on their way out, if I can force the boost then I get a random msifires. I am hoping that the plugs are super worn and that is the cause...
Old Jun 25, 2017 | 08:21 PM
  #93
g60wall's Avatar
2014 E63s
Ever solve it? I didn't need to replace my coil pack apparently it was just the plugs. Car is a monster blew up the transmission street racing just got a level 10 built trans installed. Love the car
Old Jul 1, 2017 | 08:21 AM
  #94
Nope same issues.
Still getting lower boost than I should be, max I see is sort of 16/17ish psi from the boost tap at the manifold side.
No idea why its doing it, I'm completely stumped and frustrated.
Old Jan 11, 2018 | 03:15 PM
  #95
An update for all:
The problem is fixed. There were a few things at play,
First, when I bought the car, the IC radiator at the front had a leak and the IAT's where through the roof, I though this was the cause so fixed that, no change.
Then I thought boost leak, engine knock, wastegate issue, bla bla bla. I could not get more than 17 psi. Car dynoed 440 WHP and 800 NM WTQ
Halfway through I involved a local tuner/racecar builder that is very good (by reputation) but he obviously could not have cared less and was just a pain in the **** the whole way through. Whilst the car was at his I got him to put a quantum ECU tune on it to see if that would change the boost levels but it did not. This was a big mistake as it added another level of complexity.
With the help of g60wall (thanks!!) and some data logging, I deduced that the torque converter slip ratio was too high, and THAT was the reason that the ECU was pulling timing and boost.
I replaced the torque converter, the TC lockup solenoid (which solved my cold harsh TC engagement) and also had the valve body rebuilt and had a sonnax kit put on the TC bore. The gearbox is now sweet and drives around much nicer than before.
I was initially disappointed as the car didn't make much more boost, 19psi compared to 17psi before. I then put it on the dyno and it did 510 WHP and 860 NM WTQ
It was then clean what the quantum tune had did, I got copies of the tables that had been changed. 6 Degress of timing advance and they had obviously neglected to increase the global torque limiter and so the car was making more power with ignition timing and less boost.
I put a eurocharged map on it and 23psi boost that holds 21psi to 5000rpm!! Only issue now is that all my plugs on one side misfire above 5000rpm so cannot dyno, but the car feels significantly faster. New packs are on there way and I hope that's the end of it now!
Thanks for the assistance everyone! Especially G60wall!!
Old Jan 11, 2018 | 03:30 PM
  #96
Welwynnick's Avatar
2006 S600
21psi at 5000rpm is terrific. Mine only does that at 3000.
Nick
Old Jan 11, 2018 | 03:33 PM
  #97
biker349's Avatar
cl600
i'm still interested in finding out how to fire the coil packs with an external power source while they are off the car. anyone figure that one out yet?
Old Jan 11, 2018 | 03:34 PM
  #98
Nick
Tell me about it, I know from the freeze frame data of the misfire codes.
I have tightened up my waste-gates quite considerably and there are no boost leaks at all, having replaced all the hissing areas (brake booster O ring, and ALL the one way valves in the breather lines in addition to the oil separator at the front of the engine which was destroyed inside.
The 65 does have slightly bigger turbo's. I do hope that there isnt a blocked cat on one side causing those misfires (and high boost) as opposed to the coil. We will see soon enough!
Old Jan 12, 2018 | 04:27 AM
  #99
I now have 4 spare coil packs, so might play around.
Getting them to fire is the easy bit, the hard bit is feeding back the ionic current measurement back to the car. I don't know how it extrapolates the data, but in star the ionic current measurement is represented as a signal from 0-4v, so I assume if you feed a constant 3v back from to coil packs to the ecu it could be fooled into thinking all is good. The downside is that you would of course loose the misfire detection, but that's not a major thing, its obvious when they are misfiring.
In addition, do you know if the ecu fires a and b coils simultaneously or in a sequence?
Old Jan 12, 2018 | 08:51 AM
  #100
biker349's Avatar
cl600
if you can just tell me how to fire them with the external power source off the car i would be a really happy fellow. that's all i need.
