M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Installed M275 Weistec Water/Methanol kit
Old Jun 10, 2020 | 06:16 AM
pmercury's Avatar
member
CL
Exclamation Installed M275 Weistec Water/Methanol kit
Installed Weistec Water/Methanol kit
still tuning but using mid size nozzle set to full at 30 psi
Water / Methanol is a must have for V12 biturbos
I hit 33.4 psi at least and full time now (my car is heavy tuned)
update, now hit 34.5 psi
Old Jun 11, 2020 | 03:27 AM
pmercury's Avatar
member
CL
transmission needs more cooling
one more radiator with fan
Old Jul 2, 2020 | 04:35 AM
2007sclass's Avatar
S550
how did meth work out for you?
Old Jul 2, 2020 | 04:40 AM
pmercury's Avatar
member
CL
I am on overtuned V12 if it worked ? I can not believe I never did this before
it is the the best addon ever if you have great cooling upgrade
I have full size intercooler radiator + 2x pierburg CWA100 + Weistec Meth/water
just sick how low my temps are and 34psi boost
a MUST HAVE
Old Jul 2, 2020 | 09:45 AM
FxFormat's Avatar
SL 600
I've always wondered what your car looks like, can you post a pic of your setup Pmercury? This is something i'd like to do for my car as well, i've decided to keep it and go all out with mods. Had thoughts about trading it in for a C8 corvette but seeing a how a tuned only MKV Supra walked it i don't think i can live with that.
Old Jul 20, 2020 | 09:05 AM
MBTION's Avatar
S65
I will follow your sugestion and will do the methanol injection to my 2007 S65.
Mine has Stage 3 Kleeman tune, cat deletes, high flow air filters and Quaife LSD, but at the dyno was reading 190+ on the intercoolers side. I will upgrade to a 10gpm water pump, but will like to know what wlse have you done on the cooling side.
Also, do you did any aditional tuning to get 34 psi? What else do you recomend we do to it?
Old Jul 20, 2020 | 12:31 PM
pmercury's Avatar
member
CL
Try meth first, good pumps, full size radiator
use the nozzle 2 and set the controller to startup 4-6 and max at 30
Old Jul 20, 2020 | 12:52 PM
MBTION's Avatar
S65
Do you mean 2 pumps? How?
Old Jul 20, 2020 | 01:47 PM
pmercury's Avatar
member
CL
you just take two pierburg CWA100 's hook one up where the old is
another one right after the radiator
both on a relay and good wiring
I added two Spal pusher fans on the front with a controller and temp sensor
https://mbworld.org/forums/cl-class-...-part-2-a.html
some say this, some say that.....I chose this
I just did this and all together with Meth injection, result is insane
even with 30C/86F I can get the engine at 80C/176F without meth
Old Jul 22, 2020 | 11:27 AM
MBTION's Avatar
S65
Sorry for the question, but do the fans come with the controler or do I have to get it apart?
Old Jul 22, 2020 | 11:46 AM
pmercury's Avatar
member
CL
apart of course
the best one I bought is here
variable
enjoy the silence
https://www.flex-a-lite.com/accessor...ntrollers.html
Old Jul 22, 2020 | 11:56 AM
MBTION's Avatar
S65
I will have to move 2 of the radiators because it has 3 sandwiched together on top and one below and I only have a 7"×22" area available as it is right now.
Old Jul 22, 2020 | 12:52 PM
pmercury's Avatar
member
CL
yes sorry
forgot to mention I removed the ABC radiator
Old Jul 22, 2020 | 01:13 PM
MBTION's Avatar
S65
yes sorry
Is that the really small one on top?
Old Jul 22, 2020 | 01:55 PM
pmercury's Avatar
member
CL
yup
Old Aug 1, 2020 | 06:25 PM
Ekselent's Avatar
SL600 / SL450 (107) / E350 / BMW M5 E60 / BMW 745i (E23) / BMW X6M / Toyota Hilux 4 WD/ Honda CBX 10
How fast at 1/4 mile???
Old Aug 2, 2020 | 04:47 AM
pmercury's Avatar
member
CL
everything depends on outdoor temps with these twinturbo V12's
since I installed the kit I did not have the time with the right outside temps to run one
the car still doesn't like outside temps over 93F 34C but that was as expected
but the difference is sick
Ill do a new 0-200 Kph video in my favorite tunnel soon
Old Aug 28, 2020 | 12:03 PM
JAYCL600's Avatar
new balance
whats you before and after IAT?
Old Aug 28, 2020 | 01:02 PM
pmercury's Avatar
member
CL
wooops not in racing, what is IAT ?
Old Aug 28, 2020 | 01:23 PM
MBTION's Avatar
S65
Intake Air Temp😉
Old Aug 28, 2020 | 02:22 PM
pmercury's Avatar
member
CL
lol
then I don't get the question as the answer is in the picture..................
and that was a very hot day
Old Jan 24, 2025 | 03:54 AM
James Le's Avatar
SL63 AMG,E63 AMG,CL63 AMG, S63 AMG
M275
I just got a m275 what do u recommend I want to go all out too!
Old Jan 24, 2025 | 06:36 PM
mrvedit's Avatar
2004 SL600
I would love to know what 0-200kph time @pmercury achieved (post #17) with his 35psi boost, but he has not been active here since 2022.
Old Jan 26, 2025 | 02:11 PM
JohnLane's Avatar
222 S-65
Also known as BenzNinja.
Old Jan 26, 2025 | 03:36 PM
mrvedit's Avatar
2004 SL600
Oh. Thanks. I am on his support service and he has helped me out several times. Will ask the next time we talk.
