M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
V12 Voltage Transformer repair and Upgrade
Rating: Thread Rating: 2 votes, 5.00 average.
Old 09-30-2022, 02:08 PM
  #201
tim687's Avatar
CL 600 '00 5.8L V12
Well I had some mouse drops on my intake a few months ago, so I need to make sure that the wiring is good.
biker349 (09-30-2022)
Old 10-01-2022, 11:53 AM
  #202
tim687's Avatar
CL 600 '00 5.8L V12
Wiring is good!
However, the newly replaced camshaft sensor is bad.
I installed the old sensors and the car ran fine. (For now)
I'll be replacing it, as it likes to work, or not based on temperature
I am wondering if the precision if the old sensors have decreased, thus allowing any timing fluctuations to become unnoticed.
biker349 (10-08-2022)
Old 10-01-2022, 02:48 PM
  #203
CaliBenzDriver's Avatar
Received 3,527 Likes on 2,349 Posts
MY'14 W212 M276 3.5NA @60kMi
salted data... adaptations !
Originally Posted by tim687
Wiring is good!
The ECU firmware adapts to these sensors. It adds salt to correct data of the measured timing.
You can get away with replacing cam sensors without Xentry but you really want it to do complete job including reset adaptations.
Old 10-01-2022, 05:07 PM
  #204
tim687's Avatar
CL 600 '00 5.8L V12
I did in fact reset the adaptations multiple times and it still wouldn't run properly. I've ordered the sensor and I expect it to arrive upcoming week.
It's going to be a tight one.
Old 10-01-2022, 05:13 PM
  #205
Making progress one issue at a time 👍👍👍
The following 2 users liked this post by CaliBenzDriver:
biker349 (10-08-2022), tim687 (10-03-2022)
Old 10-03-2022, 05:05 PM
  #206
Michael Pitts's Avatar
2005 SL65 AMG
Are you going to do it by yourself?
When the time comes, yes! Just preparing for the eventual.
biker349 (10-11-2022)
Old 10-07-2022, 02:03 PM
  #207
tim687's Avatar
CL 600 '00 5.8L V12
Mercedes-Benz original sensors or aftermarket premium sensors? I've bought Delphi ones and it is shaking like a potato sorting machine.
Even after resetting the adaptations multiple times
Someone working at Mercedes told me that these cars do not always like non-Mercedes sensors.
The original sensor came with this logo, can you identify the brand?
Also, the sensor didn't install flush with the valve cover, is this an issue? I can't tighten it up any further
Old 10-07-2022, 02:56 PM
  #208
nop
Have you tried searching for the part number to see what description comes up with the many brands suppliers.
Old 10-07-2022, 03:22 PM
  #209
tim687's Avatar
CL 600 '00 5.8L V12
I did, nothing came up. I've got the feeling that this is one of those manufacturers that got bought up by a larger one.
Any ideas about the tolerances of the sensor compared to the camshaft?
Old 10-08-2022, 08:26 AM
  #210
tim687's Avatar
CL 600 '00 5.8L V12
I've reinstalled the sensor and it's more flush with the cylinder head. Engine idles some what good, but cylinder 7 and 12 both miss when giving some gas during cold idle.
It did this before I think, but it would usually go away
Old 10-11-2022, 02:49 AM
  #211
tim687's Avatar
CL 600 '00 5.8L V12
Long live Germany! I've hit 210 on the autobahn, it wouldn't go any higher cause I setted the wrong speed limit.
The car does misfire a little at idle with 102 octane.
Starting when cold outside is still a challenge and takes some attempts
Old 10-17-2022, 10:09 AM
  #212
2005 SL65 AMG
MPH?
I went over 160 once and that was a bit scary. Can't imagine 210.
Old 10-17-2022, 10:32 AM
  #213
tim687's Avatar
CL 600 '00 5.8L V12
Originally Posted by Michael Pitts
MPH?
HAHA nope km/h. I've reversed the speed limiter back to 250km/h and indeed it's going 250 now
Old 10-31-2022, 03:25 AM
  #214
tim687's Avatar
CL 600 '00 5.8L V12
So I've replaced the camshaft position sensors with the ones that are actually made for the car and she starts up beautifully.
However, when using the rev-range, one cylinder is misfiring and that causes massive vibrations.
Any suggestions?
Old 12-06-2022, 02:28 AM
  #215
arkiteckz1990's Avatar
2001 CL 600
HELP ME TOO TIM
I’ve read this whole thread, great thread.
I have MISFIRE ON CYLINDER 7,8,9. Sometime 9s goes away, I replaced spark plugs and boots, MAF,MAP.
car will run good for 6 minutes until I come to a complete stop, misfire will pop up.
So right now I have code for cylinder 7,8, o2 bank 2 sensor 1 02 bank 1 sensor 1! Says heat circuit Issue.
Do I need to buy voltage transformer or coil packs?
BY the way I got 7,8,9 codes and the o2 sensor literally a week after I did a muffler delete. Kept the cats stock of course. Please let me know WHAT I GOTTA DO!!
Old 12-06-2022, 10:24 AM
  #216
brucewane's Avatar
2005 SL600
You might want to try replacing your fuel filter - check this thread, very similar problems mentioned and they resolved with a new fuel filter.
But if you do need to diagnose ignition issues, v12icpack.com will rent you a voltage transformer and/or coil packs for testing. Information is about halfway down their home page. You can also send in your voltage transformer to be tested for $25.
They've also just announced availability of their own redesigned/improved voltage transformer which mounts remotely instead of on top of the engine. The stock top of engine location subjects the voltage transformer to a lot of unnecessary heat, shortening its life.
The following 2 users liked this post by brucewane:
earl3 (12-26-2022), RUFAZZ (12-06-2022)
Old 12-26-2022, 09:37 PM
  #217
earl3's Avatar
09 SL65
Thanks Brucewane! Just ordered a Boost Box from Clark. I will provide a basic review once I receive it but knowing his reputation I expect zero issues. My current transformer is fine, but I know it's day of reckoning is inevitable.
Old 07-29-2023, 10:14 PM
  #218
MKnightMD's Avatar
2006 CLK 500, 2010 S65 AMG, 2010 S63 AMG, 2006 Navigator, 1995 Ferrari 456 GT
1600 HP????
WOW
Old 08-17-2023, 07:19 AM
  #219
tim687's Avatar
CL 600 '00 5.8L V12
Has anybody got more information about the 23V circuitry? @pmercury , do you have any schematics or traces?
I need to find out how the 23V from the diode reaches the connector
Old 11-01-2023, 06:53 PM
  #220
Fried Chicken's Avatar
2005 S500 Designo
Is there an updated voltage transformer parts list? Was PMercury able to figure out what parts to replace?
I can't believe this thread got derailed like this. One of the most interesting and useful threads on this board.
Old 03-13-2024, 01:49 PM
  #221
2005 SL65 AMG
Another one bites the dust
Mine just died. It has a manufacture date of mid December 2008. It was a replacement for the original. I've ordered Clark's redesigned unit from v12icpack.com to replace this one.
One of the capacitors took a crap. Everything else is visually okay.
Old 03-13-2024, 01:58 PM
  #222
abril's Avatar
'72 280SE '63 220 '03 CLK 200
You can replace them with some better ones and it should last you a long time,you can try replacing the caps your MOSFETs might be ok and you will have a spare unit. Also I would desolder that capasitor so the fluid won't eat your PSB if you plan to fix it up
Michael Pitts (03-14-2024)
Old 03-13-2024, 05:31 PM
  #223
solder failure
This is a typical solder failure. It's caused by a combination of:
  • low temp "cold solder" joint
  • (vibrations of cap if not glues down)
  • Lead-free ROHS weak solder
  • high current spikes
Lucky this looks perfectly salvageable as PCB is not charcoaled.
This is your wake-up call to clean and resolder every similar solders at your earliest convenience.
Your solder iron needs to be temperature regulated to heat pins reliably within soldering temp range.
Michael Pitts (03-14-2024), tim687 (03-14-2024)
Old 03-14-2024, 12:42 PM
  #224
2005 SL65 AMG
Thanks for the info CaliBenzDriver!
I've experienced plenty of cold solder joint failures in my lifetime, but have never seen it accompanied with burning. I haven't measured anything yet, but it looks (and smells!) to me like the cap failed. This stuff smells to high heaven. Sorta fishy mixed with the "magic smoke". This must've been on the edge for a bit because this happened at a few seconds after start up. Sounded great then almost immediately the engine tone changed and the check engine light illuminated. I suppose it was running on just 6 cylinders.
My plan is to source and replace ALL of the caps and if that fixes it, keep it as a spare. Although I shouldn't need it since I just ordered one of Clark's Boost Box replacement VTs.
Old 03-14-2024, 02:03 PM
  #225
2005 SL65 AMG
Well, this doesn't look very promising.
What's the best / easiest way to get rid of the potting material?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: V12 Voltage Transformer repair and Upgrade
