V6 spark plug torque specs and recommendations
C280
Does anyone know the V6 (280) spark plug torque specs.
This is my first time changing plugs on a Benz, anything I should watchout for?
And what plugs do you recommend?
Thanks guys.
Thanks guys.
C280
Thanks guys.
Thanks guys.
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
28Nm. I would say in the M112 engine, use ONLY the plugs recommended stock (and no substitutes).
-s-
-s-
C280
-s-
-s-
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Any pitfalls to watch out for? These are probably the original plugs I am taking out. Should I wet the area down with some liquid wrench first?
C280
Originally Posted by sosh
No need to unless you have one thats stuck. Remember you have 12 plugs. When installing use some anti seize on the threads. Sounds like you have never done this before. If thats the case have someone do it for you and watch.
Of course I'm a little worried that the original plugs might be difficult to remove after 5-6 years. We will see. I know plenty of people who aren't too fond of 100,000 mile plugs.
95 E320 Cabriolet, 108K
In extreme cases of hard-to-remove plugs, you'll want to use lots of liquid penetrant, removing the plugs hot, perhaps using some back-and-forth action with the wrench, or any combination of these techniques.
Ditto on the antisieze.
What've you been driving that you've never worked on aluminum heads? This is unusual nowadays.
C32AMG
Done plenty, just never on an alum. head.
The box that your new plugs are in probably specifies tightening the plug a specific amount after the its' gasket contacts the head.
C280
I'm going to buy my plugs this weekend. What do you recommend?
Should I go with what the book says, or I spend the extra money and go with the Iridium plugs (those are the $10 a piece plugs, right)?
Can any gains be had here, other than just having new plugs?
C280
Originally Posted by Kestas
Like scorchie said, go with original. These 'premium' plugs are sometimes a problem for MB engines.
I'm going to my local Advance Auto Parts store and just in case they don't have the originals I might be tempted to buy another brand.
Anyone try the +2?
C280
My local store only as the Bosch plat +2.
There is a pep boys around here, but its a pain to get there. I'll give them a call.
Called Pep Boys and all they have is the +2 also...WTF is going on?
Other than Bosch, what do you recommend?
C280
For whatever reasons, my local stores do not carry the OEM plugs...
I'm planning on changing my plugs tomorrow, so I'm looking for other than originial plug recommedations.
Bosch +2, NGK, autolight, Denso, whatever works.
