Exhaust Smell, Cats gone bad?
Old Oct 13, 2006 | 07:18 PM
C24owner's Avatar
'08 E550 4Matic
Hey guys,
This has been going on for some time now and Im sick of the smell. After hard acceleration I get this foul odor, Im almost positve that the sulfur content in the gas is ok since Ive refuled countless times since this first started. Ive seached the forums and didnt get a clear answer if replacing them (with some high flow cats ) make the smell go away?
Any help would be great.
Old Oct 13, 2006 | 07:51 PM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
A quick test of the cats is to find someone with an OBD2 scanner that graphs sensors and look at the before/after (upstream/downstream) O2 sensor voltage swings. If the after/downstream O2 sensor's voltage output looks close to the before/upstream O2 readings, then that cat is running inefficiently. How inefficient is determined by the swing ratio (or switching ratio). Of course, this assumes that the O2 sensors aren't defective.
Just my $0.02 worth.
Regards,
paul....
Old Oct 13, 2006 | 08:17 PM
C24owner's Avatar
'08 E550 4Matic
Regards,
paul....
Thanks for the quick reply. A good muffler shop should be able to run the test, right?
Old Oct 13, 2006 | 09:57 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Perhaps the Cats are worn out and the catalyst is shot. This can be caused by bad fuel or a bad O2 sensor causing it to run rich. Sometimes if you catch it in time and change the O2 sensors if bad you may get the odor to go away but more times than not the cats need to be replaced. Remember CATs are a part that does wear out but usually if all else is correct it will not happen for many miles over 100K.
Old Oct 13, 2006 | 10:47 PM
paulv's Avatar
If the muffler shop does other repairs (tune ups, etc) then they would most likely have an OBD2 scanner.
Regards,
paul...
Old Oct 13, 2006 | 11:09 PM
C24owner's Avatar
'08 E550 4Matic
Thanks for the help guys, I will get both things checked out.
Old Oct 14, 2006 | 10:17 AM
whoover's Avatar
'19 E63S sedan
BTW, check it soon. A sulfur smell is usually not a sign that the cat is bad, but is overheating. That's usually because the air-fuel ratio is off because of an engine problem. The excess fuel causes the cat to overheat and will do further damage.
I would take it to whoever does your engine work, not a muffler shop.
Old Oct 14, 2006 | 11:25 AM
C24owner's Avatar
'08 E550 4Matic
Thanks for the heads up Whooer. I'll bring it to one of my guys on tuesday and have them take a look.
Old Oct 17, 2006 | 12:08 PM
C24owner's Avatar
'08 E550 4Matic
Just got back from the shop. MAF sensor and o2 sensors are good. Cats are good aswell.
Pre-Cats 240 in and 290 out
Main cats 300 in and 380 out.
Everything checks out good. What now?
Old Oct 26, 2006 | 04:19 AM
Sword's Avatar
Some vehicles may experience sulfur like or rotten egg odor coming from the exhaust. Under certain operation conditions the sulfur may collect in the catalytic converter. When the engine operation parameters change, the sulfur that has collected can be expelled as Hydrogen sulfide (H2S). H2S has a characteristic rotten egg odor. The amount of sulfur in the fuel sold in California is regulated; however the sulfur content sold in other states can be significantly higher. Sulfur content can differ considerably between gasoline brands and location.
A sulfur odor coming from the exhaust does not necessarily indicate there is an issue with the engine running condition. Try following: 1.Change brand of fuel. 2. Change grade of fuel. Note a brand or grade change may take several tanks before a reduction of the condition can be detected.
Old Oct 26, 2006 | 09:53 PM
shorthair's Avatar
2014 C300, sport, black/black
Is the car still under warranty?
Maybe the dealer has bulletin for it? Or a TSB? Anyone know?
