Intentional crank but no start how-to?
Old Dec 9, 2006 | 09:54 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Intentional crank but no start how-to? (C55)
Does anyone know the correct procedure to create a no-start condition. By correct way - I mean to not damage any components or create any codes.
What is the correct fuse or relay to pull? Model is a 2005 C55 AMG.
The reason is that I want to build oil pressure at slow crank speeds, prior to starting normally, as the car will sit for long periods.
Thanks.
Last edited by kjb55; Dec 9, 2006 at 02:25 PM. Reason: updated with C55 model info
Old Dec 9, 2006 | 04:10 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
I personally don't believe that is necessary if you are using the suggested oil type and weight. You might create more of a problem by disabling the ignition. Just start it and let it idle for a minute or so.
Old Dec 13, 2006 | 09:19 PM
kjb55's Avatar
Whether it is necessary, I agree, is questionable. It's more of related to my OCD regarding the ownership of the car.
Anyone with any suggestions?
Old Dec 13, 2006 | 09:41 PM
sosh's Avatar
OCD?? Maybe a shrink could help you out better than the guys on this forum.
Old Dec 14, 2006 | 09:23 AM
kjb55's Avatar
Only those with gasoline in their veins understand.
Old Dec 14, 2006 | 11:41 AM
sosh's Avatar
Gasoline in your veins?? Then you need more medical care than a shrink!! Actually I have Jet Fuel in mine!!
Old Dec 14, 2006 | 12:57 PM
kjb55's Avatar
Any chance of getting the correct answer to the original question???
Old Dec 14, 2006 | 02:19 PM
SUNILP's Avatar
2015 E250D
How long are you going to let it sit? YOu cannot create a slow crank situation. It's either crank or no crank. If you want to crank it without starting it, then pull the fuel pump fuse in the rear sam module on the left of the trunk. I think it's fuse 5. Should be 20 Amps. Or you can hand crank it with a long breaker bar at the crank pulley. Either way, I don't think you need to do this even if you store the car for a few weeks. Just make sure a trickle charger is hooked to the battery. Mercedes sells one at the dealer.
Old Dec 15, 2006 | 09:52 AM
kjb55's Avatar
Thanks Sunman for your reply. The car could possibly sit for as long as 6 months. I have a 'smart' 750mAmp battery tender installed. The crank speed RPM, as best I can research, is approximately 400. This is about a 1/3 of the initial cold start idle. My intention is to no-start crank 3 cycles at starter speed to circulate fluids.
I thought that MB outlines a method to do just what I am trying to accomplish to perform a compression test, but I can't locate any documentation.
My concern with pulling the fuel pump fuse is that the fuel rail will remain pressurized and the injectors will pulse, allowing fuel to inject and a mis-firing start that will set codes.
Old Dec 18, 2006 | 07:32 PM
MBTech21's Avatar
05 ML350, 85 300D
If the car is sitting that long, don't worry, there is no pressure in the fuel rail, the check valve is designed to hold over night..not over 1/2 year...
Old Jan 5, 2007 | 03:37 PM
sergs99m3's Avatar
M3, E55, SL55
pull the fuel pump relay or fuse.
