Help Please Transmission Slipping
Here's my problems.
My transmission seems to be slipping, sometimes when i'm driving the car it seems fine but when i take a corner the trans slips into nuetral on it's own, i'll pull over turn off the engine, start it back up and the vehicle will drive normally. the same problem also happens when i floor the gas pedal and let off right away, kinda like when your trying to pass a slow driver. i punch the gas, let off slowly once i've passed and then give it gas again and BAM i'm in nuetral. it's freaking dangerous people, this happens daily. If i'm driving the car in triptronic instead of slipping the car will lock in whatever gear it's in.
WTH can it be, if i have to buy a whole new transmission i'm just going to part ways with my car, i really don't want to do this becuase my cars bad ***. i'm hoping it's not too expensive to fix, maybe a couple hundred bucks but if it goes into anything over a G i'm done people.
https://mbworld.org/forums/s-class-w220/176320-my-car-almost-got-me-killed.html
Dropping into neutral may still be mechanical, but could also be a problem with the transmission control module. As babason says, sometimes they develop leaks. They are much cheaper to replace than the tranny itself. You need to have a dealer or transmission shop diagnose the problem.
My web site is still under construction, almost done, I bought the template that way, I inserted the car and sound, and my target date is the end of this Month, in English.
Thanks for asking, any comments about it.
